Old 02-26-2010, 02:20 AM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Rear diff tricks???
Howdy folks,well one thin leads to another! Im making steady progress towards the poor house and divorce on this 72 Chevy C-10 LWB. Before I install the new brake cylinders I thought I may as well see about axle seals,yoke seal(which is wet with oil)and cover gasket. My question is; Can these 12 bolt rear ends be made into a limited slip or positrac type rearend? Or do you have switchout the whole rear end for another type? I seem to remember a kit that installed and would lock both axles. Input? Ideas? Thanks you guys!
Ironangel is offline   Reply With Quote
Old 02-26-2010, 05:15 AM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Rear diff tricks???
The 12 bolt truck 8.875 axle has a pretty good aftermarket following as far as posi/locker selection goes . No need to swap the entire axle . The eaton posi seems to be well liked .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 02-26-2010, 05:33 AM   #3
72armyswbtruck
72armyswbtruck's Avatar
Yes the eaton posi works great, a little pricey for my blood.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 02-26-2010, 08:21 AM   #4
cdowns
cdowns's Avatar
best "trick" i know of with rears is to have money and drop off at a shop for rebuild then pick it up in a day or so
Old 02-26-2010, 02:11 PM   #5
Ironangel
Ironangel's Avatar
Farout! Thanks guys,Im going to eatons website now
Old 02-26-2010, 04:08 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
x2 on that - just tell them what ratio you want and what diff. Eatons are good, but kinda pricey, I had an Auburn 'High Performance' LSD in my '92 C1500 w/ 10 bolt and it worked great. I would recommend it, and the price is good too. I got mine through Jeg's, but had the rearend with new 3.73 gears professionally set up.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-26-2010, 04:36 PM   #7
big_al_71
big_al_71's Avatar
We just redid the complete rear end in my truck. It came out perfect and it definetly has held up nicely, no noise...highly reccomended!!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-26-2010, 02:26 PM   #8
hayhauler71
hayhauler71's Avatar
http://www.summitracing.com/parts/PWT-1910-LR/ I used one like this and works great and takes less than 1 hour to install.
hayhauler71 is offline   Reply With Quote
Old 02-26-2010, 03:06 PM   #9
epashhans
epashhans's Avatar
I have looked at that before. You said you used one like it...do you know which one? Under the applications listed it doesn't show a 67 c-10, which is what I have, but I would like to find something like this.
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 02-26-2010, 03:52 PM   #10
hayhauler71
Call Richmond gear for your application mine was a 12 bolt in my 71
Old 02-26-2010, 02:40 PM   #11
leddzepp
Moderator
leddzepp's Avatar
Click on my build link below. I recently changed all the seals and gasket on my rear axle.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-26-2010, 04:42 PM   #12
nuke1
nuke1's Avatar
I got 3.73 Richmond gears with a Detroit True Trac locker
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-26-2010, 05:01 PM   #13
grs
I thought 12 bolt rear ends were positrac. My 69 has a 12 bolt , and it is a positrac.
grs is offline   Reply With Quote
Old 02-26-2010, 06:00 PM   #14
dirtball
dirtball's Avatar
Some are, most are not.
Brett
dirtball is offline   Reply With Quote
