02-27-2010, 03:14 PM | #1 |
TUKE-NoBullChit Customs owner
easiest way to check front suspension?
hopefully ill be getting an alignment on monday, ill be lowerring my truck just a bit this weekend. i want to make sure they dont try and tell me i need some $125 ball joint that i coulda replaced for $25 before i got there. so is there any easy ways to tell whats wrong?
i called myself checking it out once before because my front would shimmy when i was braking, and sometimes when driving certain speeds. looked to only be a outer tie rod, so i replaced it and its worse now when i stop. im hoping the alignment will take care of it, just want to check it all out before i go. |
02-27-2010, 03:20 PM | #2 |
Formerly- 1972SuperCheyenne
Re: easiest way to check front suspension?
Sounds like the rotors or drums are warped if shimmying while braking. Not to sound like a jerk, but if you dont know what to look for when checking safety items, lots of places will do a courtesy inspection for free. My shop does. Then if you feel inclined to do so, take it home and repair whats needed. You dont want to "guess" on safety related items. Let a trained technician check it out for you.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-27-2010, 03:24 PM | #3 |
so theres no real way for me to check these things before i go to the alignment shop myself?
02-27-2010, 03:28 PM | #4 |
Yes, lift the truck on a jack and see if theres any play in the steering by shaking the wheels side to side and having someone look at the steering components. Shake the wheel up and down to check wheel bearing play. Then you can put a pry bar under the tire and pry up against the ground to check for ball joint play. Also look at the upper and lower control arm bushings to see if they are cracked or not.
02-27-2010, 03:31 PM | #5 | |
02-27-2010, 07:26 PM | #6 | |
p.s. i've spent a year doing nothing but brakes in school so if this is wrong take it up with both my instructors, one of which is ASE master tech so... good luck with that
02-27-2010, 03:33 PM | #7 | |
Life is Good !
Mine was doing the same thing, i repaced the rotors with out turning them, out the box and on the truck. Replaced everything else and it was still doing it. Took the rotors in as a friend suggested and they were really warped. Replaced them put on new brakes and all was well. Wish I would have turned the rotors to start with, would have saved me some $$$$, but the front end is all new now, so I know its SAFE Take your rotors to a parts house and have them turned... IMO
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" Last edited by landon4421; 02-27-2010 at 03:34 PM. |
02-27-2010, 03:35 PM | #8 | |
02-27-2010, 03:22 PM | #9 |
Badass
the alignment shop will check that before doing the alignment. they will not do the alignment if everything is not good.
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
02-27-2010, 03:27 PM | #10 | |
my dad seems to think i can align it pretty well with some string and a 18" level....lol too bad i tried this once on my blazer about 4 times a long time ago and learned my lesson. made me laugh though |
02-27-2010, 03:33 PM | #11 | |
Badass
02-27-2010, 03:26 PM | #12 |
Badass
lift up the front of the truck.and shake the from wheels and see if theres move ment.and have someone look where its coming from.
02-27-2010, 03:29 PM | #13 |
well i did that much and everything seems tight now that ive changed the tie rod end. so im thinking i should be good and just check my rotors some kinda way? maybe i can get rid of the shimmy when i brake and the alignment will hopefully take care of the rest
02-27-2010, 08:10 PM | #14 |
Badass
the school is paying for this test this time (: only aloud to pick two. so i think im going to try engine performance and idk the other one yet
02-27-2010, 08:15 PM | #15 |
lucky... so lucky...
02-27-2010, 08:20 PM | #16 |
Badass
and the funny thing is,i dont even plan to have a automotive career. i want to get into airplane machines.
