![]() Join Date: Jan 2009
need help rear axle questions
man here in town has a 5 lug 12 bolt leaf rear axle for sale. he claims it come from a truck and i going to look at it. my 69 is leaf rear and i want to use it for my 5 lug swap. what are the differences from a 67-72 leaf rear and a 73 up? are they the same width from back plate to back plate? just dont want to buy something i cant use. thanks for any help
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
Big Red - Now its a SWB!
Re: need help rear axle questions
I know that the leaf spacing is different between a 67-72 and a 73-?. other than that I think that the 73+ have a 10 bolt not a 12 bolt, that is easy to spot
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
yea stuff like that. i can measure the distance on my axle between the leafs a check for a difference. i think i see a post were somebody said the leafs were different widths? anybody know??
#4 | |
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
I didn't know that. Are they the same internals, axles,etc as the earlier ones?
thanks for the responses guys. my truck is a 2wd if they was some confusion there. i have seen the replacement axles you can get from ECE but i can get this rear cheaper. does anybody know about the width of the springs?
Same as the 72, but as LHM said, the shock mounts are wrong and the spring perches are or might be different.
do the mods mentioned above and you'd have the more modern 10 bolt rear under your truck. don't worry about a wider track width as the front is always wider anyway on a stock setup. especially on a 4x4 with the front wheels that stick way out, a wider rear would make it look more balanced.
its all about the +6 inches
I know on the heavier trucks there was more than one width of leaf spring.
Look at the shock mounts, if staggared, then it was certianly out of a later truck. |
