03-03-2010, 12:41 PM | #1 |
Packrat
'72 K20 w/4" lift.
72 K20 long bed w/4” lift (blocks in rear) 350/TH350/205 D44HD front axle, 4.10 Eaton HO54 Full Floater Rear Axle, 4.10 has rocker rust and cab floor rust, but better than normal for Iowa trucks... New Stuff put on. gas tank, sender, grommet, cap Crate 350 Engine, dual exhaust heavy duty trans cooler shocks overload spring leaves for rear Holley 600 cfm carb, electric choke carb adapter 4-core radiator heater core 285/75R16 Firestone Destination AT tires (33”) neoprene seat cover Master Cylinder and Booster gas pedal D44 large bearing spindles and installation incl. shafts, ujoints, etc… Spicer D44 upgraded u-joints heater controls rebuild kit front bumper bolts transfer case full reseal battery tray front upper and lower ball joints dome light lens assembly manual wiring manual Haynes manual heater fan switch tie rod ends front axle pinion seal rear axle pinion seal halogen headlights rear brake lines, shoes, cylinders, seals, 2 tail pipes custom made heavy duty running boards, D44 pinion seal labor Used Stuff I put on it. seat from '69 GMC tailgate hood cowl 16x7 Chrome Blade style wheels grill and surround, logo mirrors front axle shafts (later model D44) topper Late 70's steering wheel seat belts (3 people) chrome front bumper door weather seal antenna Stuff Not Installed that goes with it…. Warn Premium Locking Hubs, New Rubber Cab Mount kit, New Rocker panels, New door hinge pin kit, New hood cushion set, New floor support overlap sheet metal, new front & Rear 8mm plug wires modified gauge cluster, tach, volt rear sliding window glove box lock and key 94 amp alternator, internally regulated
gone: --'07 Tahoe LTZ 4WD --'68 Firebird 400 Convertible gone: --'72 Chevy K20 |
09-29-2010, 04:20 AM | #2 |
Re: '72 K20 w/4" lift.
Is this for sale? if so need details~
09-29-2010, 10:05 AM | #3 |
Packrat
No for sale. I was thinkig about it, but ended up selling my '96 Yukon instead... and made this my tow rig...
09-29-2010, 01:44 PM | #4 |
ah i see i see, well let me know if you spot any 67-72 4x4 leaf spring chassis roller's or frame around your area I'm in need of one asap
