03-03-2010, 07:38 PM | #1 |
lowering the front of a 62.
so i have the torsion bars twisted all the way down and it still isnt low enough. what else can i do to get it lower?
03-03-2010, 08:28 PM | #2 |
Re: lowering the front of a 62.
Drop spindles.. Some say you can put a longer bolt in the torsion bars but that bolt will end up scraping the ground. I have also read pulling out the torsion bar and re inserting it a half turn will get you a little lower but I have not tried that nor can confirm it. Drop spindles of 2.5 and with torsion adjustment its fine for me. If you want to slam it then you should swop out the front crossmember to a later chevy truck.
Reid |
03-03-2010, 09:31 PM | #3 |
thanks for the help. i might swap the front stuff to a later model 60s setup with the springs up front. what all would i need to do this swap?
03-03-2010, 11:41 PM | #4 |
03-04-2010, 08:07 PM | #5 |
seems like it would be alot of work
03-04-2010, 09:44 PM | #6 |
No matter what theres gonna be some work involved. I put the 2&1/2 dropped spindles 6 lug discs. In hind sight wish I would have swapped front crossmembers mainly due to exaust clearance issue and those dumb bolts that hang from the torsion bars.
03-05-2010, 12:48 AM | #7 |
Yeah, the bolts are the worst part.
Look at this pic of my old 60. You can clearly see the bolts hanging really close to the ground under the cab. Thats with torsions turned as far as can go, bumpstops totally removed, and Toxic Shocks. It rode really pretty decent, but I drug those bolts constantly....and sometimes if they caught just right on a pothole or speedbump, it was semi-violent...
Tim Road Hounds |
03-05-2010, 06:51 AM | #8 | |
"Where were you in '62?"
That's what I did! And I dropped it more!
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 03-05-2010 at 06:56 AM. Reason: http://public.bay.livefilestore.com/y1p6PO8bDrId5gmsSwjRMZAyLZkajCfdcK91JsrAvqzsko0aQkLUi8IiJ3P83yfnvLVerSM7UajYAuCbPVFzcUERQ |
03-05-2010, 08:37 AM | #9 |
One day...
I swapped mine out with a 74 chevy cross member, with 2.5 drop spindles and air bags, it gets low enough
03-05-2010, 10:17 AM | #10 |
could i swap it out to a 63 cross member and get everything from it?
