03-03-2010, 10:15 PM | #1 |
Ready to go fast!!
Big Block Chevy Turbo kits?
anyone have any ideas what these cost or any info on a good start?
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
03-03-2010, 10:24 PM | #2 |
Re: Big Block Chevy Turbo kits?
i dont think anyone makes kits for these trucks, but id just make my own. you can buy all the stuff pretty cheep and if you got a little fab skills you can do it. what are you looking for ? are you doing it to the truck in your sig ?
03-03-2010, 10:52 PM | #3 |
Ready to go fast!!
no really a kit for the trucks... just for big block. what do i need? and yes im doing it to my pro street 72. check out my build thread.. "just a kid with a dream" i know im gonna have to lower the compression
03-03-2010, 11:22 PM | #4 |
ShortBus KingPin
2 88mm dryer's (at least), blow thru carb, wastegates, boost controller, stainless headers, downpipes, cold pipes, bonnet for carb, some type of intercooling, timing controller, BOV, ETC..... It ain't cheap to do, but 10lbs of boost on my 505, I was making 1200+hp. It isnt any fun on the street though. That is why I sold everything and went natural. It was suprisingly streetable. You are 3 months late. I gave a buddy one helluva deal. If you shop around and know what you are looking at and for. You can get alot of parts on the cheap.
A couple of close friends are in the Outlaw racing scene and are always upgrading their setups. I'll keep my ears out for some good compressors.
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE) 2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE) 2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE) |
03-03-2010, 11:19 PM | #5 |
what heads do you have ? you might be able to just get heads with bigger combustion chambers. are you going to go fuel injected? or blow threw carb ? what kind of fuel system do you have now? you might want to upgrade that ! i just hope you got a bunch of money ! lol ... it gets expensive quick !!! you gonna go single turbo or twin ? twins might be a little cheeper because you can get used t-4/t-3 ones on ebay cheep and you can just buy shortie headers and flip em up. just gonna be a lil more plumbing. if i were you ... id read all i could on turbo setups befor i even thought about spending a dime !!!
03-03-2010, 11:32 PM | #6 |
do lots of reading up on turbo set ups , i just finished doing a single turbo setup on my 383 stroker, fuel injection is the way to go way easier to tune , i got a blow thru set up on my truck which is the cheaper way to go
the turboforums is a great site to read up and learn off of for turbo systems |
03-03-2010, 11:34 PM | #7 |
Ready to go fast!!
midevil1- u sound like u know ur **** lol i really dont know anything about it except they make tremendous power... i thought about using nitrous to get it spooled up off the line until they are fully spooled.. im just tryin to get some info under my belt before i go blowin money
03-04-2010, 04:49 PM | #8 | |
If you chose the right turbos you wont need nitrous. You're not running a 4 cylinder here! LOL. |
03-04-2010, 10:33 PM | #9 | |
The right combo of parts will yield a streetable driver and more then enough power.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
03-04-2010, 11:04 PM | #10 |
ShortBus KingPin
If you want your turbo system to fall off.....??? Then use mild steel headers. They WILL crack. Exhaust temps double over a naturally aspirated, nitrous'd and supercharged application. You wont have any problem spooling the turbo's unless you plan on using some smog legal oval port heads from the early 80's.
I ran 10 to 1 compression, 10lbs of boost and water/meth kit. I had 10lbs of boost at 3000 rpms and was dumping the rest. Truck was VERY streetable, but I could get NO traction when the boost came up. That was with the 31/18.5 hoosier cheater slicks on it. A set of 80mm turbo's like an HX-80 off of a N-14 cummins would work great and are cheap. My experienced opinion...... Here are some videos of my close friends car, who happened to help me with my turbo setup. This car was built in the 2 car garage. EVERYTHING was built by the guy with the skinny get away sticks. This motor is a 598 IHRA ALL-ALUMINUM prostock ford motor. 2800hp.
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE) 2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE) 2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE) Last edited by midevil1; 03-04-2010 at 11:26 PM. |
03-04-2010, 11:13 PM | #11 |
ShortBus KingPin
My pics and videos of my trucks old setup are on my crashed COMPAQ. Trying to recover everything on that laptop. I will post some pics and vid's of my old setup if I can save the info off the laptop. Lot of memories stuck in that piece of crap laptop......
03-05-2010, 09:37 AM | #12 |
Sorry but that is complete crap. I've seen more SS headers crack then mild steel. A lot more work is involved when using SS when making headers. Cheap 304 SS will fall apart. I've seen pleny of instances where mild steel has worked very well from mild 5-600 hp setups to 1500+ setups. Mild steel not working for a turbo setup is a myth. While SS is the better option of the two, it's not the only option.
03-04-2010, 09:09 AM | #13 |
twin 88mm are pretty large for a 454. You don't need SS headers, a good set of mild steel would work fine. An intercooler isn't required either, but it does help.
You can build a 1200 hp BBC with twins or single and it can be very streetable if you build the right combo. In order to provide some advise we need to know what parts you want to keep, what you are willing to spend (cheap to someone else may not be cheap to you) and what your goals are. 9 sec time slips, 1000 rwhp??
03-04-2010, 11:29 AM | #14 |
Try twin 68mm or 70s. twin 88's are for big time power - go to the turboforums for anything turbo related.
03-04-2010, 12:29 PM | #15 |
a marine procharger kit just didn't sell on ebay for $350. now it's relisted and up to $400 this time. i almost offered him $300 last time just to have
03-04-2010, 02:51 PM | #16 |
http://cgi.ebay.com/ebaymotors/CHEVR...Q5fAccessories check this kit out. a big block would easily provide the airspace for this set up. it allready has a boost referenced fuel pressure regulator. the only things that you would have to buy is or build is the exhaust manifolds. do big block shorty headers and flip them upside down you may have to cut the collector and re tig it to tuck the snails under the hood a little better. this kit is a really good deal though. you can get this kit a little cheaper then that as well. ive seen them go for as cheap as a 1g flat with free shipping. and you might even be able to talk to the guy and tell him you dont want the exhaust manifolds. for cheaper prices ya know. anyways i hope this helps. oh and DEMON makes a production blow through carb allready and its cheaper then sending in a carb to have the base plate vaccum ports added and teflon floats and boost referencing the meteoring blocks to constantly equalize the pressure. you will also need a higher pressure fuel pump. more then your average 6-8 psi fuel pump.
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
03-04-2010, 10:39 PM | #17 | |
03-05-2010, 02:36 AM | #18 |
hey man you said a start up kit, and considering most big named guys run a PT106 on their big block set ups those two turbos wouldnt be not enough. and you never specified a budget thats why i recomended that carb its cheaper then the blower shop or anywhere else for that matter cuz its mass produced. good luck.
03-05-2010, 03:04 PM | #19 |
SS headers, when done right, is the best option (like I said), but mild steel is also a good option. It doesn't have to be a junkyard build. Like I said plenty of big hp/big money engines running mild steel. It all depends what you have available to you and what kind of money you have to spend. My turbo build is far from a junkyard build yet I am using mild steel headers.
I made my statement because you were putting false information out there. Just because you use SS doesn't mean it's the only option. I'm am just trying to provide a all the options with a bias point of view.
03-08-2010, 11:59 AM | #20 |
Hey sorry to be a thread jacker, but the Ebay link that was posted above for the twin turbo kit. Any one know anything about a kit like this? I emailed a few people that bought the kit off ebay and everyone was happy with their order. One was even a custom shop out of Mississippi. Thinking of getting this kit for my 383.
03-08-2010, 02:09 PM | #21 | |
03-08-2010, 10:10 PM | #22 |
If you have some money check out the following link. Some very nice kits.
The ebay (chinese) kits are hit or miss. Just as long as the turbo's are sized properly for what you want to do. You need to determine what your goals are before you can size the turbo or turbos.
03-08-2010, 11:38 PM | #23 |
those kits are way popular on the turboforums.com on a "stock" small block the thing made almost 700hp at the wheels.... they are solid.
