Old 03-04-2010, 01:43 AM   #1
rico7769
Hybrid67
rico7769's Avatar
Extra Number/Letter in Vin???
Team,
I've looked into the info on the VIN for my truck and can't find out why I have an extra number based on the year.
The VIN stamped on the plate is CS1570C P7645A
I get the CS1 but can't find get the 5 as a code for a 67. Then the 0C ???
The P is for Pontiac and then the sequence number 7645 for production. Any input on the "A"?
I'm confused???
Also, the SPID shows an axle code of 1FS025 (as best as I could read it from the orig sticker being faded)
Can't find any info on what the correct axle ratio is for this????
Please help!
Steve
Keep em' Running!
All show.....no go
rico7769 is offline   Reply With Quote
Old 03-04-2010, 06:50 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Extra Number/Letter in Vin???
It's not a GMC, perchance is it?
CS157OC-P7645A
C= 2 wheel drive
S= L6 engine
1= 3,900 - 5,800 # half-ton
5= ?
7= 1967 [maybe]
OC= Stepside,'67-'68
-= space for special codes NY, PA, MD
P= Pontiac, Mich. Assembly Plant
7645= Sequence number after 1001
A= ? [could it be a '4' ?]
GMC used a letter code for years: A= '69, B= '68, C= '67, Z= '70, 1= '71, 2 = '72.
Just a stab at it. Using the LMC catalog p 10 chart. By no means accurate.
In the Model ID numbers, '57' means 115" wheelbase (shortbed).
Could it be:
C= Conventional, 2wd
S= L6
1= 1/2 Ton
57= 115" wb
OC= Stepside ['67 + '68]
- = nothing
P= Pontiac plant
7= 1967
6454 = vehicle sequence number.
--Or-- 7645 and "A" = 1969 ?
Can't tell w/o seeing the truck in person.
Maybe some real expert can chime in.
Old 03-04-2010, 09:33 PM   #3
rico7769
Hybrid67
rico7769's Avatar
I'll see if i can get a shot of the door plate that is stamped to get some better visibility to it for the rest of the team to see.
Steve
Keep em' Running!
All show.....no go
Old 03-04-2010, 10:12 PM   #4
Rod
C= conventional cab
S= six cylinder engine
1 = 1/2 ton
57 = cab to wheel base dimension which a 57 denote 42 inches
0C = fender side box
space for state identifier if applicable - in this case its not.
P = Pontiac assembly plant
7645 serial number
A = 1969
It's an odd version.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-06-2010, 05:48 AM   #5
'68OrangeSunshine
Well I wasn't off by much. I was mislead because Rico mentioned 67. Chevy called it a Stepside but GMC called them Fendersides, or something. [And Ford called that bodystyle a "Flareside" if I'm not mistaken.]
Old 03-06-2010, 09:32 PM   #6
Rod
Well rico7769 is it 67or 69?
Old 03-07-2010, 09:57 PM   #7
rico7769
Hybrid67
rico7769's Avatar
based on the dash bezel and the front clip having the vertical "custom" badges I would bet a 67. The bed is off of a 68 with side markers. I bought the truck two years ago with a 77 sb350, a TH400 tranny from ??? and a 67 (i think) cab, and the bed a 68.
Keep em' Running!
All show.....no go
Old 03-08-2010, 06:15 AM   #8
'68OrangeSunshine
A '67 cab is most likely to have a small back window. However the large 'Panoramic" back window was available as an option on the '67s. '68s and later it was standard.
What would tell you it's a '67 would be the different style of locks on the vent windows. The pure '67 has ridged horizontal lines on it. '68s and later are smooth. '67 glovebox doors are wrinkle/ flat black. All this assuming the parts are original and unmolested. A Frankenstein truck would be more likely assembled according to builders' parts availability, as they come in or are acquired.
Do the front fenders have side marker reflectors?
Old 03-08-2010, 09:23 PM   #9
rico7769
Hybrid67
rico7769's Avatar
Vent window handles are ridgid and there are no front side markers.
SPID says lg panoramic window and customer appearance pkg or something like that
Keep em' Running!
All show.....no go
Old 03-09-2010, 07:23 AM   #10
'68OrangeSunshine
Sounds like a 1967 truck to me.
Do the parking lights go completly out when you pull the Lights knob all the way out?
I wonder who else can try decoding your vin?
Old 03-09-2010, 08:39 AM   #11
OhioDan
OhioDan's Avatar
Thumbs up Re: Extra Number/Letter in Vin???
Ya might check here? Found this. Hope it helps?
http://www.6066gmcguy.org/VinNumber.htm
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 03-09-2010, 11:53 PM   #12
rico7769
Hybrid67
rico7769's Avatar
THanks for all the input. We'll keep pluggin away.
Keep em' Running!
All show.....no go
Old 03-10-2010, 12:53 AM   #13
Rod
By your description I'd say 67 also with a panoramic rear view window option. The last letter in some vins, as in your case the "A" was to refer to a range of GVW as in the 60-66 vin decoding styles. "A" meaning 1/2 ton gvw range. That would work as its a 1/2 ton I'd assume, but there is really nothing to identify the year in this vin if thats the case.
Odd vin, its like they missed a letter.
Old 03-10-2010, 01:58 AM   #14
'68OrangeSunshine
So send it in to the GMC Guy. Then post his reply back here. I'm curious to see what he says.
