03-04-2010, 07:11 PM | #1 |
sharp as a marble
Three on the help
Well this old man stepped on his tongue today. I have a 69 c-10 in my shop, and it had a cheapo floor shifter in it that was worn out. I told the owner I had everything he needed to make it a TOT. Well, I almost had everything. My 69 was a TOT, but mine is a v-8, his is a six. The frame engine mounts on mine are in the front two holes, and his are in the rear two holes. I have what I think is the correct rods that run from the column to the trans, but IF all of you 6 cyl guys would help a brother out with a picture or two My morning might go better
I would also be much appreciative of this Chip |
03-04-2010, 08:36 PM | #2 |
Re: Three on the help
Isn't the transmission in the same location for both applications?
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
03-04-2010, 08:43 PM | #3 |
sharp as a marble
I know that the engine mounts are different. IF the trans was 4" or so forward I would be done by now. I am assuming that the shift linkage is a bit longer. I have a good friend that has a small junkyard, and went to him this afternoon. he gave me a set of linage from what he says was a 6cyl TOT. They are a bit longer, and hopefully will work.
This thinking thing is giving me a headache! |
03-04-2010, 08:44 PM | #4 |
whatca want a pic of?
Learning as I go! ------------------------------------- |
03-04-2010, 08:45 PM | #5 |
there is a u shaped bracket that connects to the block for the z bar, do you have the z bar?
03-04-2010, 08:57 PM | #6 |
here are the two pics i had, hope it helps.
03-04-2010, 10:29 PM | #7 |
I think the bracket on the frame is different between the 6's and 8's. I have some pics, but I need to find them. I'll go look.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
03-04-2010, 10:39 PM | #8 |
This is the set-up for a six:
03-05-2010, 08:22 AM | #9 |
sharp as a marble
thanks for all of the help, but I guess I did not ask the correct question. Are the shift rods longer for a 6cyl ? the two rods that run from the column to the trans. My friend gave me a set that look similar, but are longer. Which is what I think I need.
03-05-2010, 06:19 PM | #10 |
sharp as a marble
the two longer **** rods were the cure. A new day, a better attitude, and wa la! The three on the tree lives another day!
