03-04-2010, 11:26 PM | #1 |
33's with no lift?
I just got some 33's for my 69 shortbed 4x4 and I was wondering how the tires would clear with no lift or if ill have 2 lift
03-04-2010, 11:47 PM | #2 |
Re: 33's with no lift?
how wide? what rims? Are you gonna wheel it hard or road use?
I have 33x10.5x15 with no lift here, but my K-10 had HD springs... I added a leaf in the rear and 1" longer shackles in the front... Only real issue is rubbing in the front when you turn.. and flex a lot... you could also add a zero-rate-leaf if you need an inch..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
03-04-2010, 11:48 PM | #3 |
MY 33's clear with very little rubbing to no rubbing. I didn't feel or hear anything and it was flexed, a vid for ref.
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
03-05-2010, 12:14 AM | #4 |
33/75/16 and i havent gotten rims yet i dont know how wide to go
03-05-2010, 12:16 AM | #5 |
My rims are about 12in wide, and the tires are 12.50s I belive. I will be putting 35/15.50/15 this and I can measure the rim's sunday If you really want me too.
03-05-2010, 12:24 AM | #6 |
yeah if you would that would be cool
03-05-2010, 12:47 AM | #7 |
SWB 4x4 Collector
Ryan, you will want a rim around 8" wide. If you have 285/75/16 for tires, they are close to 33" x 11.50 x 16. Those are the same size tires I run on my Rubicon. I think you would benefit by adding a 2 1/2" lift with those tires. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
03-13-2010, 04:45 PM | #8 |
Board member knsmodels has a '72 with 33X12.5X15 and no lift on his. I just talked via PM with him about it. His is the green truck pictured. I put the same size on my '71 but it has about a 1 1/2" block lift front and rear. I have a Tuff Country 2" front and rear spring lift sitting in my garage waiting to go on. . . waiting for the snow to melt and get some warm days though. I put the wheels/tires on and drove it around without a rub. Its the red one.
'71 K10, ps, pb, a/c, tilt, tach and LOTS of rust |
03-15-2010, 10:34 PM | #9 |
zz
03-15-2010, 10:35 PM | #10 |
thanks guys 33's look great!
