03-06-2010, 09:34 AM | #1 |
You want it there when???
Leaf Spring Question
I have a 86 Silverado swb with a steel flatbed and I pull a 16 ft trailer and 2 other trailers with it and I am fixin to swap out the rear leafs. It now has 3 leafs per side which would be better 5 leafs or 6 leafs what is ya'll opinion? tks
1986 Silverado Flatbed 400 SB with 350 turbo 1997 Ford Explorer with 302 mydrive to work ride 1978 Gmc Midas RV 21ft with 46,000 actual miles 2003 Chevy Avalanche 5.3 327 and Tweety Bird Yellow Big Sandy Survivor 09 Trucks in the Blue Grass Survivor 09 TNCTC Streetcruzin |
03-06-2010, 11:45 AM | #2 |
Re: Leaf Spring Question
9 is better!
Only 3 and running a 16' trailer? Add as many as you can especially if towing weight with a trailer, in my opinion. Good Luck! Mark
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." |
03-06-2010, 11:56 AM | #3 |
yeller
If you switch the rear springs out (commonly refereed to as 53" springs) for HD versions, it is likely they will be the longer ones (commonly referred to as the 56" springs)...and you will need to move your rear spring hangers on your truck back to the next set of holes on the frame in order to install them.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
03-06-2010, 06:00 PM | #4 |
I wish you were closer to me, I have a set of 1 ton rear springs that I am gonna end up scrapping cause nobody will take them.
82 C60 82 C20 (neverending project) 77 Mercedes 300D (gets me to work) |
03-07-2010, 12:59 AM | #5 |
I would go 7 or 9.......I think the ones i took off my 1/2 ton 2wd were 7 leaf. see if theres a big truck spring shop around ya, we got one here and they can make new leafs.
