weatherstripping question
I bought new weatherstripping for the doors/glass on my '68 GMC.
The window felt along the dividing post between the window and vent looks quite different. The kit I have is from Steele. The OEM piece looks like chromed steel, and is rigid. The felt inside is disintegrating, but looks to be riveted to the chromed part. The new piece is not rigid, and has no holes for rivets. 1) How is the new piece supposed to be installed? Remove the old material inside the chromed channel, and glue in or drill holes and rivet? 2) To get the old stuff out of the channel, do I need to remove the vent window (as described here )? Should I remove the rivets or just scrape the old stuff out? To remove those rivets, does the vent seal need to be removed first? Do I need to remove any of the other weather stripping to get the vent out? 3) I'm not ready to repaint yet, so, if I install the vent window seals now, can they be removed undamaged later when I am ready? I've seen mention of a rivet kit in threads about the vent seals. Where would one purchase that? Does it include the rivets for the main window felt too? 4) How do I remove the beltline weather stripping (that wipe the window) later without damaging it. The old stuff has no rubber or felt left and I pulled the clips loose with pliers, but that bet the metal core. I'd hate to do that to the new stuff when I'm ready to paint. |
#2 | |
Re: weatherstripping question
picture is drawing of the liner with S/Stl edge the second is the replacement bar Last edited by mbgmike; 03-07-2010 at 01:52 PM. |
Thanks.
What weather stripping do I need to remove to get the vent assembly out? As for Steele parts, I bought the stuff from Rubber The Right Way as part of a group buy on another forum. Though it was a good deal, but didn't not know who made the stuff til it arrived. |
I would say that it would make it a lot easier to take the vent window out. That channel probably pushes from one end to the other.
#5 | |
Just the door rubber at the top and the window wipes. Nothing wrong with Steele Rubber parts, just have to know what you are getting |
#6 | |
I certainly didn't know there was more than one option for that channel felt. I wasn't asked about different styles. Do you carry the rivets for the vent window? I don't see them on your site. How much are they? |
#7 | |
we carry everything to do the windows Pivot revits are 50 cents each and the division bar rubber like a $1.00 per window or we sell complete boxes of 50 |
optomistic ah-so
Steele would have had the version you needed, too...but it's an option you have to request at order time and from the sound of things the group buy organizer though everyone needed his type of fuzzies.
I'm also sure if you called Steele now, they want to charge you for all the right pieces; but they would tell you exactly what's different in the kit from what you need. One reason I can share from other restos (albeit Mopar), that rivet holes are not pre-drilled is because assembly standards for vintage and antique autos were not as consistent as we expect them to be now. The rivets used at different production locations would be different sizes and different locations. If it was me, I'd pay attention to how Mike showed up and offered to help, it goes a long way in my book in choosing who I spend money with on fixing things...but it wasn't Steele's fault so much as a backfire on the group buy concept that stuck ya with the wrong parts. Steele's expensive and don't cut anyone slack on prices usually, but that's because they have products they can be proud of.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. ![]() Last edited by CSGAS; 03-07-2010 at 08:44 PM. Reason: clarification |
#9 | |||
I'm still new to this truck and didn't think to ask 1) what brand the parts were, 2) if there were options. The parts weren't listed on the seller's site, and I just asked for parts for a '68 GMC C1500. Quote:
The vent side of the divider does have rivet holes pre-drilled. Quote:
Much like Rubber the Right Way, Mike has a lot of parts that aren't listed online. Makes shopping harder. |
