03-09-2010, 12:15 AM | #1 |
v8 swap question
Hey all, I have a 93 Bravada that I am putting a 383 into and I have a few problems. The main one is, with the correct oil pan and motor mounts, no matter how much I try to add in spacers, the oil pan still sits on top of the front differential. Is there a different set of mounts that I should use? Different oil pan? Help... this is getting irritating. Thanks!
94 Ford Aerostar AWD Which is useless in Florida... 86 FJ1200 Daily Driver |
03-09-2010, 02:38 AM | #2 | |
Re: v8 swap question
http://www.v8s10.com/Pages/Parts_S10-4x4OilPan.html http://www.v8s10.com/Pages/Parts_S10-NewOilPan.html http://www.summitracing.com/parts/ADD-716411A/ http://www.summitracing.com/parts/HAM-1099/ What motor mounts are you using? EDIT: I just reread your post, you said you are using the correct pan, which one are you using?
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper Last edited by FLEET72; 03-09-2010 at 02:44 AM. Reason: Post script |
03-09-2010, 05:59 AM | #3 |
So Many Ideas, So Little Money
is the AWD t-case and front axle setup the same as the standard 4x4? that'd be the only reason I could see...
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
03-09-2010, 02:02 PM | #4 |
The front end is the same as the 4x4. The transfer case is what makes it awd or 4x4.
I can still count my vehicles on two... wait three hands. |
03-10-2010, 07:40 PM | #5 |
03-09-2010, 10:16 PM | #6 |
i can't imagine why Big C could have problems if its same as standard 4x4. theres plenty of 4x4 s-10s out there....
03-09-2010, 11:54 PM | #7 |
Hey,
I am using the Advance Adapters oil pan, and JTR style mounts with 2.8 frame side mounts, if that helps anything.
03-10-2010, 01:02 PM | #8 |
look like this one?
03-10-2010, 04:56 PM | #9 |
Yeah, that's the one I have.
03-12-2010, 06:50 PM | #10 |
Could you post some pictures of what you have?
