Old 03-09-2010, 12:18 AM   #1
pestwagon
help me buy the right piece-turn signal
newbie here- All four of My 66 truck's turn signals all work but I need to hold the turn lever down firmly to keep them blinking left, if I don't then I can hear the relay switch click on/off but no left blinkers light up. If I push the lever up it blinks right, and I dont need to hold it in place. But it doesn't return to normal with either a left or right turn, so do I need a $10 cancelling cam? Or a $95 turn switch? TIA...
pestwagon is offline   Reply With Quote
Old 03-09-2010, 11:09 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: help me buy the right piece-turn signal
It's been too many years since I've been inside one of these to remember the pieces exactly, but in the absence of a better answer I'd suggest pulling the steering wheel and taking a look before spending any money. There are several small pieces prone to breakage and I'm not sure this can be diagnosed accurately without visual inspection. Just make sure to disconnect the negative battery cable before pulling the wheel.
Old 03-09-2010, 01:42 PM   #3
creep
Registered Loser
creep's Avatar
It sounds like you need a new switch assembly. http://www.classicparts.com/1964-66-...info/53%2D508/
I did mine last year and it was pretty easy. Just remeber how everything comes apart so you can put it back together correctly.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 03-09-2010, 05:51 PM   #4
forestb
forestb's Avatar
Make sure you look at the switch before you buy a new one. Mine has what seems to be the original column in it but the wrong year switch.
forestb is offline   Reply With Quote
Old 03-09-2010, 10:21 PM   #5
BMSJaX
BMSJaX's Avatar
Just did this yesterday Dark1 has a good step by step here
http://67-72chevytrucks.com/vboard/s...d.php?t=388586
1964 Chevy C10 a.k.a. Julie Ann
H.E.I. cause its better to be pointless
BMSJaX is offline   Reply With Quote
