Lowering
How low could I go before I would have to notch the frame?
Thanks |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Lowering
I have had better than half a dozen of these trucks lowered 6 inches in the back without c notching any of them. I use ECE springs and do still haul with the truck so they don't get pampered. No issues with bottoming out.
Some guys will say 5 inches is the lowest without notching, but I can only offer my experience and ECE's recommendations.
Re: Lowering
Ok great. I was actually thinking about doing a 4/6 drop so this is awesome. Do you think I could lower it 6 inches with the stock springs?
Re: Lowering
You will have to change the springs to do a 6 inch drop.
Re: Lowering
ok thanks a lot!
Re: Lowering
Also one more thing, what did you do in combination with the springs or was it just the springs themselves?
Tot Roddin'
Re: Lowering
Kevin is right... 6" rear spring and you will be fine.
Lowered shocks and shock relocators to change the angle of the shock otherwise it will continue to bottom out.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 03-09-2010 at 10:26 PM. |
Re: Lowering
And an adjustable track bar to recenter the rear end...
Re: Lowering
alright thanks
Tot Roddin'
Re: Lowering
Just contact ECE and they will set you up right.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
![]() Join Date: Jan 2007
Re: Lowering
