Old 03-09-2010, 11:28 PM   #1
rex01atv
Sway Bar problems??
My 2000 silverado 2wd is lowered 5/7 with DJM lower/upper a arms with belltech springs. I removed my sway bar and sent the truck down for alingment, now when I re-installed the bar and bushings it seems to be raising the truck about 3/16'' of an inch??? I installed with the truck on the ground so all the weight was already on the springs and frontend. Do I need different mounts??? I have the bar installed straight to the frame with bushings and the ends are attached to the lower arms with the long bolt with bushings and spacer. HELP!!!!
rex01atv is offline   Reply With Quote
