Old 03-10-2010, 07:00 PM   #1
jsinor1956
Question swap 64 gauges to 66 what is needed?
I am changing 64 gauges with idiot lights to 66 gauges, with what is needed? I have wiring for both clusters. The plugs look the same, Do you just plug em in and thats it? Or what other wiring mods and parts are needed.
Jim
jsinor1956 is offline   Reply With Quote
Old 03-10-2010, 08:48 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: swap 64 gauges to 66 what is needed?
Plug n Play
DPowers is offline   Reply With Quote
Old 03-10-2010, 11:12 PM   #3
daverod
SSN 706
daverod's Avatar
You have to change the oil sender and the temp sender. The oil sender needs a line that will screw into the back of the gage. Temp sender is the one wire type. I did it but I'm still in the process of finishing it up. I'm pretty sure you can still use the wires that go to the temp gage you just use one and make sure you hook the same one to the gage. Any auto place has the oil pressure sender. I used the copper type, seemed to work ok. Leaked alittle at first because I never tightened it up good enough.
daverod is offline   Reply With Quote
Old 03-12-2010, 12:04 AM   #4
daverod
SSN 706
daverod's Avatar
Rays chevy restoration site has a write up how to do it.
Old 03-12-2010, 12:49 AM   #5
Vernski
Dave do you have a link to the write up thanks....Vernski
Vernski is offline   Reply With Quote
Old 03-12-2010, 12:54 AM   #6
Slow Build
Slow Build's Avatar
Quick question since we're on the subject of gauges. Other than the 5 screws on the front, what else needs to be done to get the gauges out? Found one at a junkyard and it wouldn't budge after removing the screws and I didn't want to stick my hands into the spiderwebs to feel around the back and didn't want to put my head on the gross carpet to be able to see the back.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-12-2010, 12:59 AM   #7
daverod
SSN 706
daverod's Avatar
I'm not sure how to do it just type it in on your search thing. It in the tech section.http://rmcavoy.freeshell.org/ Damn I'm good. Ok it was really easy. All this talk almost makes me want to finish mine. Maybe this weekend. The main reason I swapped was so I could put in a tech. Then I switched to a hei And I'm not sure how to hook it up.
Old 03-12-2010, 01:05 AM   #8
protrash64
Resistance is Futile
protrash64's Avatar
Also need to remove the speedo cable and the oil line going to the gauge. Probably some electric harness, too.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-30-2010, 11:11 PM   #9
EVBuilder
EVBuilder's Avatar
Slow build... there is a tach lead right on the side of distributor cap for that. It's even labeled "tach" if you can get in there to see it if not remove the cap and you will see it.
EVBuilder is offline   Reply With Quote
Old 03-30-2010, 11:13 PM   #10
EVBuilder
EVBuilder's Avatar
Sorry wrong name it was daverod....
