Old 03-12-2010, 09:38 AM   #1
brandon7925
Lift question. please help!
I just bought a 1980 k10 4x4. i also bought i 4" lift but the lift springs for the front are 2 1/2" wide and the stock leaf springs are over 3" wide. I've never lifted a truck before so i'm scrambling trying to figure this out. did i buy the wrong springs or what? thanks
brandon7925 is offline   Reply With Quote
Old 03-12-2010, 10:55 AM   #2
Burt4x4
Burt4x4's Avatar
Re: Lift question. please help!
What is brand of lift is it? I would call them and crosscheck the part numbers...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-12-2010, 02:35 PM   #3
brandon7925
i wish i knew. i bought it used.
Old 03-23-2010, 04:57 PM   #4
mango
i just had that problem yesterday when i was installing a 6" skyjacker lift on my 69 k10. it was only on the front shackle of the rear springs so i just made a steel spacer to put in between the shackle and spring. i dont know if it was the right way to do it but it looks like it should work just fine although i wont be able to realy tell untill i finish the build
mango is offline   Reply With Quote
Old 03-23-2010, 05:08 PM   #5
msgross
msgross's Avatar
3" in the middle or the eye of the spring? If it slops around in the spring hangar then you are going to have to ditch them or make a spacer i guess. Sounds like you got the wrong years. Check the length too...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-24-2010, 12:44 AM   #6
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yep pretty much x2 man. Sounds like the wrong ones but I don't know without being there lol!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 03-23-2010, 11:28 PM   #7
72blue
72blue's Avatar
Depends if you have the correct bushings. They should have 0.25" thickness on each side if they do. I would be more worried about spring length, they were different in the 72 and older. See if you have the correct bushings to make up the spring width difference. I have National springs and they are 2.5 wide and they came with bushings that are quarter inch wide on each side. Hope this helps.
James
James
72blue is offline   Reply With Quote
