Old 03-13-2010, 04:29 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Pine Wood Bed Floor Pictures / Question
What is the best finish for pine wood floor. Any pics of pine wood floors?
1971ChevyTruck is offline   Reply With Quote
Old 03-13-2010, 11:41 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Pine Wood Bed Floor Pictures / Question
I'm not sure what the best finish would be but I always thought I would try clear Lacquer. I would mix the first coat a little thin so it would soak in good. I'm not a wood finisher so I may be all wet with this. Anyway this will get you back to page one...
LockDoc
Leon
Old 03-14-2010, 12:00 PM   #3
MVHandy
A good polyurethane, rub out between coats and make sure you get all of the ends really good as well as all 4 sides of the boards or it will absorb moisture and bubble off.
MVHandy is offline   Reply With Quote
Old 03-14-2010, 02:44 PM   #4
LockDoc
LockDoc's Avatar
I don't think you can do all 4 sides because the wood has to "Breath".
LockDoc
Leon
Old 03-14-2010, 06:55 PM   #5
gkesseru
gkesseru's Avatar
From a woodworker:
1. You need to do the bottom same as the top or else the bottom will absorb more moisture than the top, expand and warp.
2. Choice of finish depends on planned usage. Will it be 100% garaged and never in the rain and sun? Then polyurethane will be fine. If not, then poly will peel within a year, maybe sooner, because the sun's ultraviolet will break down the molecules.
3. If it will be in the weather only rarely but in the sun a lot, then spar varnish will hold up better. It has ultraviolet blockers.
4. If it will be an outdoor truck, then don't use pine. The factory did use southern yellow pine sometime in the past, but that is not easy to find now.
5. For outdoor use, white oak will work fine because it is not a porous wood, but do not use red oak for any truck that will get rained on because red oak is totally porous and will eventually rot.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 03-14-2010, 07:11 PM   #6
msgross
msgross's Avatar
I plan on using a "marine" type product.... if it works on a boat, it will work on a truck.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-14-2010, 09:29 PM   #7
Fitz
Roger That!!!
Fitz is offline   Reply With Quote
Old 03-14-2010, 11:30 PM   #8
knsmodels
I make Models
knsmodels's Avatar
you want to coat all sides....leaving one side unfinished on wood is a bad idea....wood does not need to breath....
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 03-15-2010, 12:20 AM   #9
Dan in Pasadena
Dan in Pasadena's Avatar
Ssshhh....you're hurting the wood's feelings!
gkesseru - What's your take on thinning marine spar varnish down for the first coat to get it go soak into the wood a little deeper? Light sand between multiple coats and final sand with like 1500 or 2000 grit?
Dan in Pasadena is offline   Reply With Quote
Old 03-15-2010, 12:43 AM   #10
LockDoc
LockDoc's Avatar
Meaning no disrespect but I think you need to do some more reading on this subject. Even I was wrong about the Lacquer...
http://www.dfcwoodworks.com/productcare.php At the bottom of the page.
Lacquer or Varnish: We do NOT recommend using Lacquers or Varnishes as they seal the wood completely and tend to bubble and peel within a very short amount of time (wood has to be able to breath , if the finish wont breath with the wood it will lift off the wood). If you want your product shinny use a good quality stain and sand lightly between each coat.
http://www.fpl.fs.fed.us/documnts/finlines/knaeb95b.pdf
High quality stains contain wood preservatives and water repellents. Semitransparent stains penetrate the wood without forming a film, allowing much of the wood grain to show through the finish. Latex-base semitransparent stains are film-forming finishes and will not perform like
true penetrating stains. Oil-base semitransparent stains allow the
wood to “breathe,” so the finish doesn’t blister or peel even if the
moisture content of the wood is high. The pigment in a semitransparent
penetrating stain greatly increases the durability of the finish by absorbing much of the UV radiation that would otherwise degrade the wood. The properties of the pigment, resin, preservative, and water repellent determine the durability of exterior stains.
LockDoc
Leon
Old 03-16-2010, 12:24 AM   #11
knsmodels
I make Models
knsmodels's Avatar
none taken.....they are referring to if you seal it completely the finish will trap all air and moisture in the wood and the sun baking on it will make this want to come out thus bubbling the finish....I was more referring to if you only finish one side or leave one side unfinished it will make the wood warp or twist.....whatever finish you go with has to be on all sides but should be something that breathes if sun exposure is in its future....
Old 03-15-2010, 11:58 AM   #12
gkesseru
gkesseru's Avatar
Dan: My choice for first coat is marine Teak Oil. It is meant to penetrate even teak, which is an oily wood. You can put this on with brush or rag, wait 15-30 minutes and wipe off excess. Do it again until it won't take any more. Dry for 24 hours, touch sand and top coat. Or else just recoat with Teak oil whenever it looks like it needs some TLC. I use wet/dry sandpaper to put on 2d coat, etc. It forces the sawdust into the pores, better sealing them and making the surface slicker.
72 Fleet (died)
78 Step (sold)
00 F150
Old 03-15-2010, 12:21 PM   #13
'68 C-20
'68 C-20's Avatar
Yes Oil. Teak or Boiled Linseed Oil, and plan on repeating the treatment from time to time. It will last longer if you can manage to limit the exposure to the sun. DO NOT LEAVE YOUR OILY RAGS IN THE TRASH CAN OR IN A CONFINED AREA. THEY ARE KNOWN TO SPONTANEOUSLY COMBUST! (That means catch fire all by themselves) Not good!
DIY body and paint work is cheap, making it look good... priceless
My Toys;
’26 Ford Model T
‘72 Triumph Spitfire 1500
'09 "The Briggs Flyer" Gettin' High.
'68 C-20 is offline   Reply With Quote
Old 03-15-2010, 02:34 PM   #14
Tkmadone
What about a good deck stain/ sealer type of product? Don't those have UV inhibitors and other good stuff?
Tkmadone is offline   Reply With Quote
Old 03-15-2010, 03:24 PM   #15
lyrikz
PITbut
lyrikz's Avatar
I JUST did this on my truck. I used minwax mahogoney red stain. Then i went over that with Mcloskey Urethane spar finish. The Mcloskey is the stuff they use on those show wood boats. Its marine grade.. After seeing my bed, i wouldnt recommend anything else.
Pics are in my build thread.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 03-15-2010, 10:22 PM   #16
'68 C-20
'68 C-20's Avatar
The spar finish will probably last as long as anything else. The only problem as I see it is when it does start to come apart due to moisture, expansion etc, (your truck bed is a plank, not structural laminate like Boat Plywood), it will be a lot harder to refinish. Maybe not, I have very little experience with marine products, but the oils will never bubble, crack, lift, or require the old finish to be removed to apply the re-fresh coat.
Just my thoughts, as the voices in my head dictate....
My Toys;
’26 Ford Model T
Old 03-15-2010, 10:38 PM   #17
COACHMEASON
Keep On Keepin' On
COACHMEASON's Avatar
Pics of the oil treated beds anyone?
07 Avalanche Z71
92 Mustang 5.0 GT (Triple White w/ 53,000 miles)
72 SWB Chevy w/ PS, AC, 350/350
Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)...
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
COACHMEASON is offline   Reply With Quote
Old 03-16-2010, 01:45 AM   #18
TripleZ
I have a question for all of you. I am going to use Mesquite for the bed in my 67 SB. I might not be able to get the boards long enough (77 1/8) I am not sure how I can put two boards together if I can not get them long enough, and make it look good. If I had to put two boards together end to end would a quality glue hold up, should I have the boards cut on the ends, a dovetail or something else.
TripleZ is offline   Reply With Quote
Old 03-16-2010, 07:46 AM   #19
gkesseru
gkesseru's Avatar
You cannot glue wood end-to-end. Only way I would do it would be to tongue and groove a middle board end-to end AND glue longer strips along each side to hold it together.
72 Fleet (died)
78 Step (sold)
00 F150
Old 03-16-2010, 12:15 PM   #20
TripleZ
Thanks Gk, what is your opinion of the two different grains at the joint. the Mesquite will have quite a difference in the grain at the joint. I have a few small pieces right now and the wood has the dark grain with some yellow in it as well. I suppose I can pick out the boards with the grain and color if I need to go the tongue and groove route. Maybe I am thinking way too much about the look. I like the single strips I see in most trucks.
Old 03-16-2010, 12:26 PM   #21
glider_6969
This truck belongs to a friend of mine, it's pine. All he did was put a light colour stain and multiple clear coats, (the picture picked up some of the dust)
glider_6969 is offline   Reply With Quote
Old 03-16-2010, 01:10 PM   #22
gkesseru
gkesseru's Avatar
TripleZ: OK to T&G at the joint, but try to get similar grain if possible. Wood swells and shrinks with humidity across the grain and not along the grain. If you match grain, then both boards will swell at the same rate.What does that mean? Summer to winter length will not change at all, but width will change as much as 3/8 inch per foot. That is why a thick plastic coat (poly, varnish, clear car paint) will eventually peel off, starting at the edges. The wood no longer fits inside the plastic container.
Also try not to have knots at/near the joints.
72 Fleet (died)
78 Step (sold)
00 F150
