Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-13-2010, 09:57 PM   #1
82Cecil
82Cecil's Avatar
Master kill swith location (pic)
Messing around with how/where I would like to relocate the battery, and discovered there was room for the kill switch on the battery box below the cable entry holes.
I've never seen this anywhere. seems like convenient locate unless someone knows a good reason not to put it there.
Thanks for your input.
82Cecil is offline   Reply With Quote
Old 03-13-2010, 10:30 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Master kill swith location (pic)
If tech matters,, NHRA says it must be located on the rear most portion of the car, easily accessible to track officials. Does that fit into your plan?
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 03-13-2010, 11:01 PM   #3
82Cecil
82Cecil's Avatar
Was thinking right rear of bed, the switch would be easy to see, but 90* to the rear exposure.
Old 03-14-2010, 10:52 AM   #4
Marv D
Marv D's Avatar
Really all it says is must be located on the rearmost portion of the vehicle and easily accessible from the outside. I don't think you would have any problem with that as long as there isn't a tailgate hiding it.
Old 03-14-2010, 02:54 PM   #5
wheatlandbrawler
wheatlandbrawler's Avatar
i would also make sure you still run a vent tube with this set up, or the it may cause corrosion on the master shut off switch.
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
wheatlandbrawler is offline   Reply With Quote
Old 03-14-2010, 07:39 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
Here is how i did mine. The tech people pass it. Got it from summit
Old 03-14-2010, 08:41 PM   #7
djracer
djracer's Avatar
I use the rod type also through the roll pan.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-14-2010, 09:58 PM   #8
69trk
69trk's Avatar
Here's a picture of mine under the bed with a drop out box... Need to make some kind of shield for it, but it's been fine for about 2years now...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 03-16-2010, 12:08 AM   #9
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Lets see some more peoples pics of how they did this please. looking very good.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 04-16-2010, 07:29 PM   #10
LJ534Rat
Not sure if legal or not with no rod?
'72 SWB 534" 10.5:1 W/GMPP 290CC Ovals,
Wilson Pro flow 2 stage,Transking man. rev T400 W/Trans brake,Moser Dana 60 w/4.30,,Indigo blue W/ghost flames,shaved,smoothed and low,9.40's @ 138
LJ534Rat is offline   Reply With Quote
Old 04-29-2010, 07:54 PM   #11
Ackattack
Ackattack's Avatar
Here's mine
Ackattack is offline   Reply With Quote
Old 04-29-2010, 10:18 PM   #12
Nick's81
Nick's81's Avatar
would like to replace my right back up lamp with a switch but will have to trim inter panels for cables 64 C-10
Nick's81 is offline   Reply With Quote
