03-15-2010, 01:45 AM | #1 |
What do I need?? To get 4 3/4 lug pattern
I have a 73+ front disc suspension with a 5x5 bolt pattern and I need to get it to a 4 3/4 pattern. Im not sure what suspension parts will fit with what and I DONT want wheel adapters. Anybody know what I need to do?
03-15-2010, 01:48 AM | #2 |
Re: What do I need?? To get 4 3/4 lug pattern
Really the only way that is feasible is to get your front rotors redrilled as well as your back axles. then you can get rear drums for a van (mid-late seventies if i recall). It is the same drum part number as the '56 Bel Air front drums.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
03-15-2010, 01:51 AM | #3 |
Ive already got the rear axle redrilled and put back together. can I order new discs with 4 3/4 that will fit with the 73+ spindle and caliper?
03-15-2010, 04:38 PM | #4 |
its all about the +6 inches
you can try car parts, but I don't know that they'll fit on a truck.
