03-16-2010, 02:31 AM | #1 |
Help with my 80 c10 olds 455
Alright peeps I just picked up a very very nice 80 SWB for a very very cheap price. Problem is it has a 455 in it the scoop I got was the previous owner was driving it one day and it just died when he went to crank it over it did nothing. First thing I did was pulled the starter and it was froze so I replaced it and cranked the truck and the starter jumped but battery was weak put another battery in it and then all of a sudden I was not getting power to anything i wiggled the pos battery cable a she was powered up again now the the starter won't even jump I noticed the key kinda hard to turn after tearing into the column I noticed someone had been in there before everything was loose! When the starter was jumping and I turned the key foward to the on position the brake lights in the dash would dim now they aren't dimming and the starter isn't budging! I feel like the points in the ignition isn't getting contact and the module looks difficult to remove so tommorrow I am heading to the salvage yard for a whole steering column my question is am I headed in the right direction or do I need to be looking elsewhere hope someone out there can help! Thanx Members for any input!
03-16-2010, 08:40 PM | #2 |
Re: Help with my 80 c10 olds 455
Update loose battery cable ha how bout that!
03-16-2010, 08:56 PM | #3 |
The One And Only !!!
That'll do it quite often, Good you didn't throw a lot of parts at it for nothing !
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
