low n' slo
![]() Join Date: Mar 2009
Rattle can paint options?
im gonna be sanding down my control arms this week and was wondering what kind of rattle can paint can i lay down and have it last? im not lookin into getting por 15 or anything, just a nice looking, durable rattle can job (if this is possible lol). just a basic black color.
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 03-20-2010 at 12:06 PM. |
Happy to be here
![]() Join Date: Mar 2000
Re: Rattle can paint options?
Krylon 1613 semi flat black
#3 | |
I dont know how rattle cans outside of cali compare to what we have (
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
You might think about using a brush. Rattle cans lay down very little paint.
I have seen thinned rustolum sprayed with a HVLP gun that looked badass...
Adam M STX Designs Motorcycles | Choppers | Hotrods |
I have used VHT paints before, spray well and hold up
1973 C10 "Chain Reaction" Street Trucks cover Feb 2012 2013 Silverado 1964 Cadillac |
Oh ya there is a VHT epoxy roll cage paint, (thats what it says on the can) thats is nice. Its says its perfect for bare metal.
rustoleum industrial thinned with acetone ... about a 50-50 mixture. both are available at your nearest lowes or home depot.
![]() Join Date: Jan 2010
Powdercoat them.
I am gonna second Shane and say Rustoleum Industrial. If you can't spray it in a gun. Lowes also has it in a rattlecan, I personally use both. Rattle cans for one or two pieces, paint gun for large products.
low n' slo
well i went to lowes and i found this stuff...
its rustoleum hammered black, for rusted/slightly rusted areas. i think they came out looking clean, i just hope they hold up. i sprayed 2 coats. thinking about doing my drop spindles now... ![]()
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Redefining LowBudget
Copy cat!!! I have thatton my front end and also looks killer on the wheels
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
you really need to smooth out those weld corners a bit more ...
low n' slo
the weld corners aren't really sharp..but I was thinking of putting a weather strip around the top just to be extra safe
#15 |
oh hey I was comparing our arms...you need to drill a hole on the inside of your cup in the corner so any water will drain and if you wanted to remove the rest of the stop just drill the welds it will pop right off
your going to love the free drop |
#16 |
low n' slo
lol. I wouldn't say it was exactly free. I paid 115 for the arms. good idea on the drain. hey what size cups are yours?
#17 |
2 3/4"..... still a good deal....if your running stock tires (29" tall) it will put your tires VERY close to your inner fender support and your going to have to do something about your wheel wells..if you come up with something simple let me know..also a 2 1/2" c notch will give you a nice stance when your dumped with a 2" drop spindle you will lay X member..not sure how much your looking to drop it but the spindles will also allow you to run the bags and control arms more in the middle at ride height....I find I bttom out the LCA when driving around real low
on a side note check your tie rods at full dump they maybe really close or rubbing the frame..that being said you can run from stop to stop with the wheel at full dump for trolling parking lots....also if you need a shock check out the monroe 5752 ( I think) there from a 50 chsyler imperial they work well with this set up
#18 |
low n' slo
thanks for the info..I pulled my fender wells out already. I plan on fabbin some up when I get around to it. lol
#19 |
couldn't find the pic..another thing is if your running a sway bar your going to need to trim some off the ends or it will hit the bags aired out..here the rear P bar pic
