![]() Join Date: Apr 2008
Seat Belt interchange
Hey, Was wanting to replace seat belts in my 79 C10. Couldn't find decent ones at pic-a-part but did notice late 80's suburban rear 3pt belts looked similar. Has anyone swapped these with success or had good results with something else?
79' Big Ten 70' 1 ton 4x4 LB "Mean Green" 70' SWB "Major Project" 69' El Camino "t-boned by Camry" |
#2 | |
Still plays with trucks
Re: Seat Belt interchange
Next time I can get to the wrecking yard I will pull out a set of Suburban rear belts and see if they fit a truck. Good chance they are the same or close enough to work and will probably have much less wear on them vs. a set of front belts.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
I have car A.D.D.
I have wondered if the belts from the 88-98 would fit. I want seat belts with only 1 retractor so I can put the kids car seats in. Do the Suburban rear belts have only 1 retractor?
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
My co-worker with a 90 Suburban says the outer two rear seat belts have single point retractors and work right with car seats. The middle seat belt in the back is just a fixed position lap belt.
