Vintage Evil
Ford 9" Conversion
I am debating on doing a Ford 9 inch conversion. I have tried to search for a thread and have not found a good one yet. I am basically wondering if there is a better year of truck to pull them from and also any other tips and tricks.
Thanks ![]() |
Re: Ford 9" Conversion
I used a 9" out of a full size Lincoln. Easy swap and it is only 1" wider than my 68 rear end. The stock e-brake cables worked!!
68 Chevy l/b, 4 whl disc in the foothills of No Calif |
Vintage Evil
I removed all of the Ford brackets and welded on the mounts from early Classics. Also got their Panhard kit.
Vintage Evil
Complete rear end from a Lincoln. T-birds also had reae discs. They are 70s vintage.
![]() Join Date: Aug 2005
here ya go :http://67-72chevytrucks.com/vboard/s...d.php?t=392566 other things to think about, E cable, driveshaft length, u joint that fits what ever pinion yolk comes with the 9". Mine is from a 75 versailles. As stated above, chop the ford brackets (save e brake cable hole)Set your pinion angle and get some early classic saddles and panhard bar/ mount.
Vintage Evil
Looked on early classics site and could not find a link to the brackets... Anyone have one?
TOTY 2006
![]() Join Date: Dec 1999
Did the same thing for my rear nine as fleetimus. Mine came from a 75 lincoln with a 460 motor.
Vintage Evil
How much is a fair price (ballpark) for a Lincoln disc brake rear end?
I would like to know more about this also
68 Chevy l/b, 4 whl disc in the foothills of No Calif Last edited by fleetimus; 03-20-2010 at 07:00 PM. |
#13 | |
Vintage Evil
Vintage Evil
Anyone else?
#15 |
What newer 9inches will work that already have disk brakes.
#16 |
I was just wondering cause mid 70`s lincolns are not that common around here
#17 |
Lincolns and T-birds had the rear disc. Have a salvage yard do a search. I believe the Versaille and Granada rear ends are too narrow. Expect to pay from $150.00 to $ 500.00.
#18 |
How narrow? If you want to put a nice wide wheel with a big lip, these might be nice! Obviously you have to buy new wheels, but who doesnt want to? (want to and can afford to, always the big issue)
#19 |
I have 15x10 on mine. No problem.
#20 |
BigBlockBobby
What gear ratio comes in the those lincoln rears?
Bob |
#21 |
TOTY 2006
Not sure on all of the ratios, but for mine, from a 75 lincoln with a 460, it has 300.
#22 |
Ford 9" has a lot of options for ratios. Mine was a 2.73 and I switched it to 3.25.
#23 |
Vintage Evil
How wide are the rear ends you are using from lincolns?
#24 |
Vintage Evil
found one out of a lincoln mark V. The guy wasnt sure on the year but it looks like they only made them from 77-79. Anyone know if that is a candidate?
#25 |
1" wider than a stock 68 c10 rear end.
