[><]Sofa King Dirty 4x4[><]
Won my class in drag racing
and came out on top as the NMCA True Street 15-second winner i took home the plaque with an average of 15.29,i got her into the 14.8's dead hookin with the 33" BFG All Terrains,She had like 32* timin so i bumped her up and went from a 15.3 to a 14.8,with a 2.5 60 foot,im gettin there. Anyways heres a pic
![]() Class Description True Street is a racing class for mildly modified to heavy modified high performance street vehicles that are street certified and able to drive over a 30-mile distance. All model years and engine types and power adders *permitted. Class is designed for stock-chassis or * back-half type vehicles running true 10.5-inch wide tires. Vehicles must be registered, licensed, and insured. There will be trophies and awards for not only the “King of True Street” (quickest average), and runner up but also for the following: Closest averaged ET that is not quicker than the following- 9.00, 10.00, 11.00, 12.00, 13.00, 14.00, and 15.00. True Street racing will be conducted at a *number of NMCA drag racing events to be specified. NMCA True Street does not have a points system. NMCA True Street is not eligible for contingency,.400 Pro Tree, Heads-Up. POWER ADDERS & POWERTRAIN All 4-cylinder, 6-cylinder, small block and big block engine types and multiple power adders are permitted. Any manual or automatic transmission is permitted. Any rear end is permitted. Exhaust system with mufflers are required. CHASSIS & SUSPENSION CHASSIS/FRAME: Stock-type chassis, as well as “back-half-type” vehicles, permitted. Stock firewall & stock front frame rails must be in stock location and unmodified. Starting at firewall rearward, floor and chassis may be replaced with aftermarket components (as in typical back-half chassis). Full tube-type chassis vehicles prohibited. FRONT SUSPENSION: Stock-type front suspension, or stock bolt-in-type replacement front suspension required. Tubular front suspension components permitted. Coil over shocks/struts are permitted. Bolt-in front suspension retrofit kits (ex. Heidt’s, Fatman, etc) are permitted. REAR SUSPENSION: Aftermarket rear suspension permitted of any design. Coil over shocks & springs permitted and may be relocated. Wheelie bars are prohibited. STREET EQUIPMENT In order to compete, all vehicles and/or drivers are required the following: 1. Valid driver’s license 2. Valid vehicle registration 3. Valid license plate(s). Dealer/Temp plates prohibited. Paper license tag will be accepted on a new model year car with current registration paper work less than 60 days old from current event date. 4. Valid insurance “ID” card. Faxes and/or letters from insurance companies and/or brokers not acceptable. 5. Valid state inspection sticker (if required by state *vehicle is registered). 6. D.O.T. Radials or D.O.T. Slicks on front and rear of vehicle. 7. Hood is required, may be made of lightweight material. Hood scoops permitted. Hood/scoop may be liftoff, must cover the entire engine & induction system. 8. OEM safety glass windows required & must be *functional. Lexan prohibited. During the tech-in process, vehicle must have *operational street equipment, including headlights, *taillights, brake lights, turn signals, and horn. TIRES: FRONT & REAR DOT slick tires or DOT legal radials tires required for drive tires during the road tour AND the True Street *competition and class run off. Racing slicks prohibited. Maximum actual measured tire size is as follows: Actual measured tread of all racing slick-type tire is limited to 10.75-inches. For D.O.T. radial tires, maximum sidewall designation *permitted is 325mm. Tire height is unrestricted. A “go-no go” gauge will be used to measured tire width. Tire *shaving is prohibited. Tire changing is prohibited during or after the road tour. Vehicles equipped from the factory with 345 DOT Radials are permitted to compete with the 345 style DOT Radial on an 18 inch rim. 30-MILE CRUISE There will be a 30 mile supervised cruise on highway and city streets prior to competition, limited to those vehicles that have passed tech inspection. A escort will supervise the cruise in accordance with local laws and ordinances. Each competitor and crew will be on their own *reconnaissance during the escort and cruise and bear the full responsibility of their actions as they would on city streets. Please be safe and follow all traffic laws *during the cruise. SUPPORT VEHICLES Support vehicles (i.e., tow vehicles, crew, etc.) are permitted optionally on the road tour, but must trail behind the True Street participants, and the escort, at all times. All support vehicles are on their own *reconnaissance and must obey all applicable local safety and traffic laws. COOLDOWN PERIOD/RETURN PROCEDURES After the vehicles return from the road tour, they will return directly to the designated staging lanes for the cool-down period. They may not change tires. The * cool-down period will typically last between 15 and 45 minutes. During this cool down period only, entrants may adjust tire pressure (add or remove tire pressure), install fresh nitrous bottles, install ice in their intercooler, (only if located in trunk, rear hatch or rear seat area). A strict CLOSED HOOD policy will be in effect until a competitor has completed his or her three back to back passes. No re-fueling allowed once car leaves on cruise. Engines must remain turned off during entire cool-down period. External cooling of engine by any means (cold water, *outdoor fans, etc.) prohibited. Any engine changes, repairs, or adjustments (changing rocker arms, *carburetor adjustments, etc.) prohibited. Changing of tires prohibited. RACE FORMAT When called to “load up” in the staging lanes, all True Street competitors must report to their cars and prepare to make three back-to-back quarter mile passes. All hoods and deck lids must remain secured, as they must remain closed until completion of all three passes. Vehicles with air-to-water intercoolers may not add ice to intercooler tank between back-to-back passes, even if intercooler tank is located in interior of vehicle. FINAL STANDINGS After all three quarter mile passes are completed, each racer’s ET’s will be added together and divided by 3. The average of these three passes will be computed. The *outcome of the 3-run average will be posted Sunday morning, and the awards presentation will be held Sunday. On a qualifying run, if a contestant properly starts, stages, and receives the starter’s signal but breaks to the point the run is not completed, a time of 28 seconds is issued and it is considered a valid *qualifying run. CREW MEMBERS Crew members are not permitted around participating vehicles, in the staging lanes, or in the burnout area, between rounds of competition. BACK-to BACK PASSES Tire pressure may be checked in the staging lanes, or between rounds, and may be lowered. Air may not be added to tires any time during the back-to-back *passes. Vehicles are required to make three full * passes in order to be included in the final average ET tally. All vehicles must run three passes in the same order as the first pass, any attempt to gain additional cool down time between rounds will result in *disqualification. The only possible exception to this rule is the use of a parachute, if required by vehicle speed. One crewmember can be placed in the staging lanes to aid in the re-packing of a parachute; however, chute must be re-packed in a manner so as not to be *disruptive to competition rounds. There will be a *separate staging lane designated for any vehicle *needing to re-pack parachutes. Any vehicle unable to start under its own power will be disqualified. Once all rounds have been completed, prize money and awards will be given based on the final average of all three *quarter mile passes. During, and in between, the back to back passes, no changes may be made to vehicle other than lowering air pressure in tires. Fresh nitrous bottles, fuel, and ice may not be installed/replenished. Vehicles with air-to-water intercoolers may not add ice to *intercooler tank between back-to-back passes, even if intercooler tank is located in interior of vehicle. No *laptops in vehicle permitted at any time once the first of the three back-to-back passes is initiated. i got the closest to 15 so i won $100 which was the entry fee ![]()
00' Chevy Silverado 1500 z71 33"s 3" lift 5-speed Past trucks 85' Chevy C10 Step side 388 stroker 33" bfg a/t's holley 670cfm world product heads 14.80@92mph 92' S10/Tahoe sbc swap Last edited by 383Chevy; 03-21-2010 at 04:55 PM. |
Re: Won my class in drag racing
Congrats man. Best I've done is make it few rounds so far. Good luck with the rest of the season. Chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
Balls to the wall!
Way to go man....representing for the c10's! Love me some drag racing !
1982 swb 1/2 ton Also have a 2001, 400+ Hp T-top Camaro SS Loving my old Chevy truck and my new square body family on here!Thanks for all the help,tips and ideas I have gotten already guys. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=388836 ............_________{\___ ............l_(0),,,______(0)l |
Well done! The index classes are tough...
How many events are you planning to run this year? I've been with the NMCA since '94 - K 2008 NMCA Original Parts Group "Nostalgia Muscle Car" #3 2007 NSCA Rocket Fuels "American Muscle" World Champion Runner Up 2006 NSCA Jeg's "American Muscle" #10 2005 NSCA Jeg's "American Muscle" #6 2004 NSCA Ramchargers "American Muscle" #4 2003 NMCA BF Goodrich "American Muscle" World Champion Runner Up 2002 NMCA/NSCA Mickey Thompson "Street Eliminator" #3 2001 NMCA Mickey Thompson "Street Eliminator" #6 JAMA Racing Ministries Chaplain to the NSCA
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
cool congrats on the win
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
