03-21-2010, 08:09 PM | #1 |
1961 crewcab
#15, a 64 gmc
my newest acquisition... a 64 gmc 3/4 ton.
I had asked the neighbors kids about this 3 years ago, and they said it was thier uncles, fast forward 3 years and the uncle came back to town, they remembered to tell him I asked about it(!?), and he stopped by and sold it to me! this one has just a mint tailgate, and the box is a 9 out of 10, it had a camper in it for 20+ years. It has a 425 caddy and an automatic jammed in it, and it "ran when parked" in 1996, and then again in 2002. I will need to fix a few things with the ignition harness, and the fuel system, but it looks like it might be a runner. probably the main reason I was interested was the factory spotlight, that will fil the hole on my 65 dd. another bonus was the "city chevrolet" emblem from a great falls dealer that is also missing off my dd. at some point he had hit a deer, and put a chevy front clip on it, and it has a real nice hood. $200!!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 03-21-2010 at 08:12 PM. |
03-21-2010, 08:15 PM | #2 |
Check The Champ, Demonstrator
Re: #15, a 64 gmc
Any close up pics of the spotlight! Is the glovebox door melting?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 03-21-2010 at 08:17 PM. |
03-21-2010, 08:27 PM | #3 | |
1961 crewcab
Re: #15, a 64 gmc
you know I guess I didn't take a pic of the light or bracket yet, I will get one next time I am out at the truck.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
03-21-2010, 08:37 PM | #4 |
Resistance is Futile
Re: #15, a 64 gmc
I just saw a 425/400 combo on C/L today and saw the front sump oil pan. That would explain the notch. Quite a collection you're building.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-21-2010, 08:24 PM | #5 |
1961 crewcab
Re: #15, a 64 gmc
are these stock for a gmc? I have another gmc with the same mirror bracket, and the sunvisors seem stock...
check out the notch they cut into the crossmember to jam that caddy in there, the cut a couple holes into the firewall as well ...and the rusty rockers were "fixed" with what looks to be 2x2 square tubing.
03-21-2010, 08:35 PM | #6 |
One foot in front of the other
Re: #15, a 64 gmc
WOW- Can't beat the price.
03-21-2010, 09:20 PM | #7 |
Member of the longbed union.
Re: #15, a 64 gmc
Nice custom speaker job you got on there. And for some reason I think they mounted the carb in the wrong place. But seeing the rest of the truck I could be wrong.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
03-21-2010, 11:59 PM | #8 |
Re: #15, a 64 gmc
I go to too much work to mount mine; I forgot they would stick by themselves!
03-21-2010, 10:36 PM | #9 |
1961 crewcab
Re: #15, a 64 gmc
you should see the fuel lines, I could probably mount that extra carb where it sits....
the seat, and tilt/teloscopic column are probably out of the same caddy the engine and trans came out of...
03-22-2010, 12:01 AM | #10 |
Re: #15, a 64 gmc
looks like they have straps on it. I be they dont have very much bass.
03-22-2010, 08:13 AM | #11 |
UCA63
Re: #15, a 64 gmc
Awesome Parts truck Jon
IIRC the sunvisors had no clips (but those look good there) The mirror head might be correct but the bracket is definitely not Good score on the tailgate,that's sweet lookin' T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
05-08-2010, 08:06 AM | #12 |
1961 crewcab
Re: #15, a 64 gmc
here is a pic of the spotlight, it said unity on the light housing, and the lamp and housing is quite small.
05-08-2010, 12:44 PM | #13 |
Senior Enthusiast
Re: #15, a 64 gmc
Thanks for sharing your photos. Not sure how you get anything done with so much to pick from. Nice score on the spotlight, particularly if you need one for your other truck. It's probably an S5 (5" bulb) instead of the more common S6 version. So much straight sheet metal for such a small price, of course that crossmember looks a bit scary.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 05-08-2010 at 12:45 PM. |
05-08-2010, 03:08 PM | #14 |
Re: #15, a 64 gmc
hey, is that a "pinto" shifter in the floor? that used to be the most common way to make a swapped in auto shift.
andy |
