Location: Where I come from, it's cornbread and chicken...
dumping dump bed
I am buying a dump bed...the fella that I'm buying it from says that he doesn't know how to dump the bed, so he doesn't know if it dumps or not...I'm assuming that the previous owner of the truck that the dump bed is on told the fella that it was a dump bed...my question is this...
how can he determine whether the bed is a dump bed or a stationary utility bed? he says there's no hydraulics, so that's out...thanks for the help in advance... Chuck. Pics Added... Last edited by Stitch; 03-21-2010 at 11:06 PM. |
It followed me home?
Re: dumping dump bed
Chuck some of the county trucks here have a dumping bed that works on a type of handle that cranks the bed up. Maybe someone took the handle off and he doesnt know where to hook it up
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
I was thinking something like that, but the question is where would he look to see if the handle was missing...lol
usually they are behind the cab on the drivers side
I'll have to direct him to this thread...maybe someone can get a picture of this area of the truck so he can see if it looks the same as what he has...or maybe he has the handle and doesn't know where it goes like you said...I really don't know...thanks Adam
#6 | |
Look at the back part of the bed if it dumps there will be some sort of hinge there, then look to the front and make sure it's not anchored in the front.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
Resident of Here
Um, does nobody in this thread know what a PTO dump bed is?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
NO what is that?
![]() Last edited by Stitch; 03-21-2010 at 11:03 PM. |
thanks fix it...
I added pics...maybe someone can point us in the right direction to where the crank handle would go...thanks fellas
#11 | |
I see a hinge in the back and that a pretty heavy bed to raise w/o hydraulics. How is the fuel filler attached I see it on the side but can't tell if its attached to the bed. It would have to be attached to the frame if it dumps.
also, could the areas circled in yellow be the crank for the dump bed...I've never owned or operated a dump bed, so if I'm way off base don't laugh...lol
and also, the area circled in red on the second pic...is that the hinge you're talking about...thanks alot man Last edited by Stitch; 03-21-2010 at 11:34 PM. |
#13 | |
#14 | |
The yellow circle is the release handle for the tailgate lock (arrow) the red circle is the hinge.
#15 |
I don't know about the fuel filler...these are the pictures that the seller sent me...
also, where exactly is the hinge...I have told him about this thread so he'll be looking at everyone's suggestions... |
#16 |
thanks for the info...could that bed be made to tilt easily if I could find a hydraulic unit to put in there...also, are there other ways besides a separate hydraulic system...could I possibly use a SM465 with a PTO output?
#17 | |
Yeah it could easily be made to dump, you'll need a hoist (scissor lift) and a dc power unit will be the cheapest route. If you went with a SM465 with a PTO output you'll then need a PTO, driveline, pump, reservoir, valve and control cable whereas the 12 volt power unit is self contained and can be wired remotely
#18 |
Crawl under there and take a look for; (yours may be different)
This is a 93 1 ton GMC The hinge ![]() The ram and leverarm ![]() The hydraulic powerpack with solenoid control. (switches in cab) ![]() The upper part of leverarm and lift frame ![]() Kits: http://www.splitez.com/Dump_hoist_ki...kup_truck.html These guys sell blueprints for the fabricator: http://www.motherearthnews.com/shopp...itemnumber=767
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
#19 | |
#20 | |
#21 | |
Here are a couple of power units the cheaper one is a single acting high/low system (power up gravity down) the more expensive one is double acting (power up power down). I saw a brand new monarch power unit sell at propertyroom.com for $120 but thats hit and miss.
http://www.grainger.com/Grainger/wwg...msRender.shtml In the photo RuralRoute C-30 posted you can see the fuel filler is attached to the chassis, in your pic it looks like the filler mounting plate may be attached to the body IMO thats the best clue, get a better photo of that area. These bodies can be monted either way dump or static with the hinge as the rear attachment point regardless.
#22 |
Robert Olson Transport
![]() Join Date: Oct 2002
there should be some kind of a metal tag stamped by the manufacturer on the driver side rear or the cab side with the manufacturer on it
You could pull it up with prolly a come along and a tow chain or even a chain hoist
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
#23 |
That is definitely a dump bed. The fact there are no hydraulics "at this time" makes it no less.
Here is a pic of the pto controls, in the cab, in my C-30. ![]() Notice there are 2 levers. The one on the right engages the pto. (place truck in neutral,engage clutch and "shift" lever forward to lock in the pto) The one on the left engages the bed's hydraulics to raise and lower the bed.(disengage clutch and pull lever back to raise bed, push lever forward and gravity lowers the bed) One word of caution if it is a pto driven dump, do not ever forget to disengage/pull back the pto lever before engaging the transmission. To do so would be "bad". ![]() The gas tank fill tube is probably supported at the frame. Can be a pain to fill depending on how it is angled. Mine is not too bad. My hydraulic tank is mounted on the passenger side of the truck opposite of the fuel tank. ![]() What may have happened is this truck "was" a dump bed but someone, for some reason or another, fixed/attached the bed to the frame and possibly removed the hydraulics underneath. If this is the case, add some real money if it needs a hydraulic pump, tank, cylinder, mounting brackets etc. Or it may have been an electric actuated dump. Not as strong as a pto but dumps. Control could be a button somewhere. Hydraulics would still be required. Other location for controls to dump are usually around the floor of the driver, even seen them tucked close to under the seat. Either way, there were controls in the cab to dump that bed unless they had a remote cabled hook-up which I doubt. Just inspect under the bed for a lift cylinder. It is either there or not. I too doubt it was a manual screw jack. That is a commercial 'material hauling' dump bed. Municipalities use a lot of them. Good beds, but always hydraulic that I have seen. ![]() I about guarantee that evidence is somewhere in that cab where the controls are or were. Yet if not, price the hydraulics you'll need to purchase before buying it as a 'dump bed'. Essentially without that what you have is a flat bed with sides and a very heavy tail gate! ![]() Good luck, keep us posted! Mark
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." ![]() Last edited by RuralRoute C-30; 03-22-2010 at 01:47 AM. |
#24 |
Didn't see the previous posts on electric dumps, good advice there too. An electric hook-up may be the way to go depending the type of transmission you have.
Once again, good luck, it looks to be solid. Can't tear 'em up without messing up! ![]() Mark
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." ![]() Last edited by RuralRoute C-30; 03-22-2010 at 01:49 AM. |
#25 |
where could I get a DC power lift unit and how much do you think it would run...man you've been alot of help to me...thanks alot
