my 85 chevy c20 diesel trans question/tips/ideas??
sup guys! well i went and got me a new project, its a 85 chevy lwb c20, 3/4 ton.
its got the diesel engine thats not running, bad heads. but i plan on pulling that out and dropping in the 454out of my old 87 chevy rust bucket crew cab dually.. heres the question... will the transmission off this diesel fit and work with my gas engine?? im askn cuz the 400 trans on my 454 is on its last legs.... i havent pulled either engine out, but wanna know ahead of time what to expect before i hit it this weeknd.. thanks.... or how is it that some of yall have converted these diesels onto gasoline.... ![]() |
Resident of Here
Re: my 85 chevy c20 diesel trans question/tips/ideas??
What tranny is behind the 6.2? 700R4 or TH400?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
x2 if the 700r4 is in their that might last for a while depends on condition if you got a turbo 400 then it will be better.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
Did this same swap with my '84 suburban several years ago, the only thing that you might run into is if the 454 flexplate has holes to line up with the converter bolts, I had to drill mine to line up, other then that it was/is a striaght swap. As for the 700R4 trans I had it rebuilt at the same time, so it was "fresh" but I used this to pull my 26' racecar trailer everywhere & have never had a moments problem with it!
#5 | |
Keep the original 454 flexplate, holes "should" be ok.
thirdstreettito ---yeah its the 6.2L diesel engine, and the transmission looks like the th400.
Matt Man---- so even even though its on a diesel engine, it will work the same if i put it on the gasoline engine? input shaft will be the same and all?? heres a quick picture i snapped of it earier today after lunch. |
Location: Where I come from, it's cornbread and chicken...
the governor and the torque converter are going to be different...you need to keep both of them from the trans behind the 454...
