Old 03-24-2010, 07:48 PM   #1
capev86
4 row radiator upgrade troubles....
hello all....
i bought a brand new 4 core radiator and all the brackets and rubber pads for the swap for my 72 suburban and i'm having a bit of trouble getting the bottom brackets off the radiator support. they appear to be welded on. i think i can pry them off with a cold chisel and clean up the holes that the new lower brackets will clip into. also thinking either to have the new one's tack welded in or a spot weld in the "bolt" hole or just use some jb weld so they are removable in the future in case i have to change out the radiator support. i can see i will have to make two notches on the lip so the brackets will fit. anyone else got some advise on going from a 2 to 4 row radiator? am i missing anything?
capev86 is offline   Reply With Quote
Old 03-24-2010, 08:21 PM   #2
skillet
skillet's Avatar
Re: 4 row radiator upgrade troubles....
I don't have an answer to your question, but was wondering where you got your radiator?
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter
skillet is offline   Reply With Quote
Old 03-24-2010, 08:31 PM   #3
capev86
i got my radiator from jim carter truck parts. it was only 200 compared to nearly 300 from most suppliers. i think i got the brackets and pads from either them or more likely lmc truck. i shopped around to get the best price obviously.
http://www.oldchevytrucks.biz/67_72/t1.asp
Old 03-24-2010, 08:35 PM   #4
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Yes they are spot welded on there. I drilled mine out, notched the radiator support & installed the new mounts (temporally) with self tapping sheet metal screws. After all that, it's a pretty standard install.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
