Old 03-26-2010, 04:25 AM   #1
layingC10nK5
laying frame with PB trailing arms
hey guys finaaly got started on my frame. im laying the rear with a set up from porterbuilt. i got the 3 inch drop trailing arms the tubular crossmember, the monster stepnotch and the shock mount bars/notch bridge. here a some pic of the progress.
layingC10nK5 is offline   Reply With Quote
Old 03-26-2010, 04:38 AM   #2
layingC10nK5
Re: laying frame with PB trailing arms
and a few more.
Old 04-02-2010, 09:15 AM   #3
aggie91
I'm just glad to be here!
aggie91's Avatar
Originally Posted by layingC10nK5 View Post
and a few more.
In the 1st two pics, is that bar that runs from arm to arm the lower shock mount? If so, I really like that idea.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-02-2010, 09:47 AM   #4
layingC10nK5
Yes that the lower shock bar came from Nate as part of the kit. I will have pics of the upper bar sometime next week.
Old 03-26-2010, 06:17 AM   #5
kev2809
low n' slo
kev2809's Avatar
I've always loved that setup. work is lookin good man..keep the pics comin
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 03-28-2010, 06:50 PM   #6
Ronm909
67GMC Slammed
Ronm909's Avatar
nice!! this set up will allow you to lay the frame in the rear?
my dropmembered 67 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383215
Ronm909 is offline   Reply With Quote
Old 03-28-2010, 08:19 PM   #7
nastyc10
nastyc10's Avatar
Looks sweet! Keep it up!
nastyc10 is offline   Reply With Quote
Old 03-28-2010, 08:51 PM   #8
layingC10nK5
Yes sir this will allow it to lay frame, I'm going to run 24" all around and this notch can lay up to a32" tall tire mine will be around 31 1/2. Unfortunately I can only work on the truck a cupple days a week so progress might be slow. I will keep posting pics and questions Im sure I will need help.
Old 04-01-2010, 09:38 PM   #9
layingC10nK5
ok guys here an update. ive been working fitting the pb stepnotch, my friend/welder wanted a "better fit and more welding surface so we dicided to box a small section around the notch. we used 3/16 plate and i got to use a plsma cutter for the first time here are some pics of the plates in, they will be fully welded along with the notch by next week.we will also start fitting the bag brackets and shock bar next week.
Old 04-01-2010, 09:59 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
Looking good!
Old 04-01-2010, 10:14 PM   #11
layingC10nK5
thanks i just wish i could work on it more often.. i find my self on here looking at pics of my own truc.lol
Old 04-01-2010, 10:32 PM   #12
GVizzle
GVizzle's Avatar
Looking good,
You gonna love that set up! Thanks for the PICs
Heres mine on a 30" tall tire
GVizzle is offline   Reply With Quote
Old 04-01-2010, 10:44 PM   #13
layingC10nK5
oh my god...that thing is sick. dang it didnt you just read i cant work on my truck too often youre gonna make me call in sick how far is the rear from the pavement when aired out?
Old 04-01-2010, 10:50 PM   #14
layingC10nK5
is it me or is your notch different? it looks wider at the bottom. im gonna have to contact nate before i weld mine in.
Old 04-01-2010, 10:58 PM   #15
GVizzle
GVizzle's Avatar
The whole truck lays flat on the ground when aired out. Including the body now ("PB Bolt in body drop" coming soon)
Not sure about the notch, that would be a question for Nate. My truck was set up for those wheels/tires and to lay frame, aired out, with a 5" ride height.
I just posted those pics up to keep you motivated, dont call in sick!!
Old 04-06-2010, 06:01 PM   #16
colin_havens
colin_havens's Avatar
The bodydrop mounts for the cab make alot of since, are simple, and will make dropping the cab nice. Im just waiting to see how Nate aligns the bumper and what he does about the bed.
colin_havens is offline   Reply With Quote
Old 04-06-2010, 06:11 PM   #17
GVizzle
GVizzle's Avatar
I can't answer on it too much because I have not seen my truck in 4 months in person, but I am sure the kit will work flawlessly and consist of a pile of mounts brackets and bolts and maybe some other surprises.....................
Old 04-20-2010, 06:28 PM   #18
ShredSled
ShredSled's Avatar
wow, that set-up looks cool! Was also reading about it on the PB site...
can't wait to see some more progress!
get it!
ShredSled is offline   Reply With Quote
Old 04-21-2010, 12:30 AM   #19
layingC10nK5
plates and notch have been welded in place (sorry no pics yet) due to the weather we have not worked on the truck much but i ordered my front dropmember with pb arms and sway bar should be here soon and that will definately get me going again...
Old 05-23-2010, 01:05 AM   #20
shores6
shores6's Avatar
lookin good! what's the plan for the front? dropmember?
shores6 is offline   Reply With Quote
Old 05-23-2010, 04:35 PM   #21
layingC10nK5
yes sir if u look at he last pic u can see the pb sway bar and the boxes holding my DM and chromoly PB arms im have to weld up the front of the frame. the p/o started a Z on it and im going to finish it. the plan is to run 24" wheels all around.
as for the track bar we have intalled a panhard bar (pics soon). i tried using a delux trac bar from early classics but it didnt work right. ended up making one from chromoly tubing and a cupple heim joints.
Old 05-25-2010, 12:41 PM   #22
kold187um
whats up big dog? yo project is looking real good!!!
i've been off work for about a month and a half, will be back after the fourth of july.
sold the 66 impala and now i'm working on a 64 impala. the lincoln will be out next week.
kold187um is offline   Reply With Quote
Old 05-25-2010, 01:01 PM   #23
kvn1011
Kvn1011
kvn1011's Avatar
24's???? That's awefully big lol
But it happens to be the same size wheel I'm gonna run too
Can wait to see more!
kvn1011 is offline   Reply With Quote
Old 05-26-2010, 01:55 PM   #24
m6z
m6z's Avatar
Looks great. What did you set the pinion anlge at? Did you set it at your desired ride height?
Thanks,
Doug
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 07-13-2010, 04:17 AM   #25
layingC10nK5
hey guys i finished all the work on my frame. pb front and rear also did the 2inch Z. tomorow im headed to powder coat and need ur opinion. the frame will be black and suspension parts purple. colors are set in stone however my friend and my brother think it will be too much purple to do ALL The PB parts purple. any input or pics of ur set-up would be great. thanks in advance. pics coming soon
