Old 03-27-2010, 02:07 PM   #1
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
69-70 Grill on a 72
I tired searching, but all I can find is pre69 grill conversions onto a 71-72. Question I have, can a 69 or 70(CHEVY) grill be used on a 71-72(CHEVY)? I know the turn signals are in different locations, but other then that, it looks to me to be an easy swap.
Thanks for the help.
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
Old 03-27-2010, 02:17 PM   #2
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Re: 69-70 Grill on a 72
I don't see why not the 71 I use to own had a 69-70 grill on it when I bought it It looked ok. I never got around to changing it before I sold it. Here an old picture.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 03-27-2010, 02:19 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
yes it can. In addition to the outer and inner grilles, you will need to swap the hood latch and the center rad support bracket as they hold the center of the grille for the 69-70. Other than that the same hood and fenders can be used. You might need to lengthen the wire for the turn signals as they are in the center of the grille vs in the bumper for the 71-72. You can choose to leave the extra signals in the bumper, convert them to foglights, or get a smooth bumper w/out the holes for lights or the new ones with the round foglights in them.
Old 03-27-2010, 02:58 PM   #4
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
its a bolt on switch!
I have a 1972 swb that I swapped the grill out for a 69 repop grill without lettering.
It fit no problem, I did not change out anything but the grill(inner and outer) and hook up the lights.
here is a couple of pics for you..
one of the grill, and one of the radiator support and hood latch...stock from 72.
Cheers!!!
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 03-27-2010, 03:19 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
so the hood latch still works with that inner grille? But there's no way the center support (between the rad support and grille) bolts to the center of the outer grille because a 71-72 is smooth in that area while a 69-70 has the bump out that bolts to support the center strip of the grille??? I wasn't trying to imply that the rad supports themselves are different (They are the same for 67-68 and 69-72); just the center support that bolts to the hood latch and the hood latch itself.
Old 03-27-2010, 03:53 PM   #6
gonzo6869
gonzo6869's Avatar
Thanks for all the help. I have always liked the look of the 69-70 grill. Now comes the hard part on deciding if I should do it. Any opinions out there?
Here is a pic of how it now.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 03-27-2010, 04:36 PM   #7
EA69TRK
EA69TRK's Avatar
I saw change it over to the 69-70 grill but my opion my be a little biasd
1969 Chevy C10 Short Step -Project
2005 GMC Sierra Crew Cab 1500 -DD
2017 Laguna Orange Roadglide - Good Weather DD
EA69TRK is offline   Reply With Quote
Old 03-27-2010, 05:57 PM   #8
72swb_327stroker_?
knuckle buster..
I understood what you meant... I was just trying to show a clear picture of how it mounted to the radiator support...
and yes it will work.
My stock 72 hood latch bolted right up to the 69 grill shell w/o mods.
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
Old 03-27-2010, 06:41 PM   #9
VA72C10
VA72C10
VA72C10's Avatar
So the center rad support bolts to the center of the 69 shell?
Maybe the PO had put in a different center support already?
Old 03-27-2010, 07:57 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
Doesn't look like he's running a center support from the pic.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-27-2010, 08:39 PM   #11
gonzo6869
gonzo6869's Avatar
I don't think there should should be a problem with out running the center support. After I got done redoing mine, I got lazy and never connected the inner grill to the center support. If not using a center support is all that I have to do, then I think I will be getting a 69-70 grill.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 03-27-2010, 08:50 PM   #12
VA72C10
VA72C10
VA72C10's Avatar
I guess I was thinking that was a during swap picture...makes sense that it'd be an easier swap w/out worrying about the support. I still don't see how the latch works but I guess they are close enough where it doesn't interfere with the inner grill.
Old 03-27-2010, 04:41 PM   #13
RW71
RW71's Avatar
I say yes, I am going to do it to my 71.
RW71 is offline   Reply With Quote
Old 03-27-2010, 08:45 PM   #14
Sinister
Between Trucks...
Sinister's Avatar
Probably not too difficult to find a center support on the Parts Board.
Beat it to fit,
Old 03-27-2010, 08:53 PM   #15
gonzo6869
gonzo6869's Avatar
True, but is really needed. I know the 72 support wont work, is it because the screw holes don't line up, or is it that it sticks out to far?
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 03-27-2010, 08:52 PM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
My 70 one ton had a 71/72 front clip when I got it, it had the 69/70 grill on it. The hood release handle was very dificult to get to, and we ended up knocking a couple teeth out of the grill for easy access.
Old 03-27-2010, 09:29 PM   #17
Sinister
Between Trucks...
Sinister's Avatar
It gives support to the hood latch which is holding the hood down against the hood springs. I'd run one.
Beat it to fit,
Old 03-27-2010, 11:56 PM   #18
gonzo6869
gonzo6869's Avatar
That makes sense. If my 72 support dose not fit I guess I will cut it to, or get a 70 support.
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 03-28-2010, 02:03 AM   #19
72swb_327stroker_?
knuckle buster..
I am not running one, nor have I ran one since I put the grill on the truck in 07. NO PROBLEMS! remember....K>I>S>S>
CHEERS!
Eric
THIS SITE ROCKS!!!
StreetCruizin
FAQ thread
