I lowered my 76 but the wheels are tilting in?? where do I need to shim to get them back straight again!!! If you have pics that would help alot to!!!!
Thanks!!!!!!!!!! ![]() |
#2 | |
Re: Need some shim help????
At the alignment shop. This is not something you can just do "until it looks right".
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
The One And Only !!!
If you have a long distance to drive to a alignment shop you can add the same thickness shims to the upper control arm mounting bolts both front and rear bolts, Then you won't tear your tires up getting there.
But, As LONGHAIR said it needs to be done/finished by professionals....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
BMW & ASE Master Certified
just like he said, Harbor Freight has a shim kit for like 5 bucks... I used that same kit to align my truck (We have an alignment machine at work)
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
