Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-29-2010, 01:50 PM   #1
shawnt
shawnt's Avatar
Question Cal-Tracs
Cheapest place to get some cal-tracs for 85 chevy swb?!
Thanks,
Shawn
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 03-29-2010, 02:00 PM   #2
Tezjoe84
Tezjoe84's Avatar
Re: Cal-Tracs
73-87ChevyTrucks.com - Caltrac's
It's Capt Chaos vendor site... he's a registered Vendor here as well
Joe
1957 Chevy 3100 Stepside
Tezjoe84 is offline   Reply With Quote
Old 03-29-2010, 02:06 PM   #3
shawnt
shawnt's Avatar
Re: Cal-Tracs
I'll check that out.. thanks alot
I've decided to build a 496 for my shortwide and im sure the factory suspension will NOT hold the power.. it doesnt really hold the power from the 355 lol.
Shawn
Shawn
85 SWB
7.39 @ 93
Old 03-29-2010, 02:10 PM   #4
Tezjoe84
Tezjoe84's Avatar
Re: Cal-Tracs
Shawn
Awsome!
Yea, a 496 is what i'm planning to build as well... it's a while coming still... gotta but the heads, then I gotta buddy at a speed shop gonna help me assemble it all.
Definately gonna be fun, but yea, at first I plan to run the caltrac's on my pickup, will definately be a test to see how well they work
Joe
Old 03-29-2010, 02:22 PM   #5
shawnt
shawnt's Avatar
Re: Cal-Tracs
Yeah, my uncle has the hookup on stroker kits, im getting eagle crank and rods, je pistons balanced for $800 so i HAVE to go that route cause it's so cheap lol. I'm buying brodix race rite ovals 270cc. victor jr, unknown hydo roller, holley 1050 dominator, msd 6al2, im gonna run the morel type lifters for sure and prolly do a lunati cam or have a custom ground cam. It's definately gonna come alive lol. BUT I GOTTA GET OUTTA THIS SH*T HOLE COUNTRY FIRST. I come home in around 80 days then it's on like donkey kong lol.
Shawn
Shawn
85 SWB
7.39 @ 93
Old 03-29-2010, 02:51 PM   #6
Tezjoe84
Tezjoe84's Avatar
Re: Cal-Tracs
Sounds awsome!
I gotta cousin that just got home from over there. Thanks for your Service btw!
I look forward to seeing yours going, sounds real close to what i'm gonna build, I'm using AFR's 305 head though, and a comp Hyd Roller. It definately should liven up the old stock big block it's replacing heh.
Joe
Old 03-29-2010, 03:14 PM   #7
shawnt
shawnt's Avatar
Re: Cal-Tracs
I've seen good numbers from 496's with the 305's from AFR. I'm using the RR's simply because people think "they don't flow well." People base off of flow numbers to much now. There is alot more important things to heads other than flow numbers. I'll let you know how the build goes ^^. I'm hoping for around 650hp but who knows. Maybe i can get into the 7's (1/8 mile) If not.. there is always the juice
Shawn
Shawn
85 SWB
7.39 @ 93
Old 03-31-2010, 08:06 AM   #8
nomrlz
nomrlz's Avatar
Re: Cal-Tracs
cal-tracs work just plain awesome
nomrlz is offline   Reply With Quote
Old 03-31-2010, 04:19 PM   #9
djracer
djracer's Avatar
Re: Cal-Tracs
I'm a believer also!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-31-2010, 04:54 PM   #10
team39763
Re: Cal-Tracs
^Add me to that list of believers too. They work awesome after you get them setup correctly.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 04-01-2010, 08:22 AM   #11
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Cal-Tracs
I had good luck with mine . The instuctions give you a starting point with preload settings , but if you have better track you can run some gap . I set mine up with about 7 different settings . I didn't use the bottom hole as it is better suited for poor track conditions . With the bar in the top hole my settings would go from the factory preload ( not so good track ) to flush with the leaf (better track ) to gapping with a dime or nickle depending on what the track will take . The bigger the gap the harder it "hits the tire" .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-01-2010, 08:32 AM   #12
djracer
djracer's Avatar
Re: Cal-Tracs
Great info. Did you set them the same side to side?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-02-2010, 08:43 PM   #13
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Cal-Tracs
I got mine from cal-tracs. 1.671 60ft foot braked on drag radials
Old 04-02-2010, 09:04 PM   #14
fiddy9apache
fiddy9apache's Avatar
Re: Cal-Tracs
can one of yall measure your bars? i want to compare them to the ones i made, im making my own traction bars and just curious.
fiddy9apache is offline   Reply With Quote
Old 04-03-2010, 08:13 AM   #15
djracer
djracer's Avatar
Re: Cal-Tracs
Cal tracs are nothing like traction bars and really need their split leaf springs.
I made a pass with a buddies girlfriend in the orange 67 camaro last night. I went 1.61 60 on motor with a 275 60 15 mickey t radial and my buddy went 1.42 with the bottle and no passenger.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-03-2010, 06:55 PM   #16
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Cal-Tracs
[quote=djracer;3898160]Cal tracs are nothing like traction bars and really need their split leaf springs.
To bad they dont make them for pick ups tho... Last time i called them anyways
Old 04-04-2010, 10:05 PM   #17
Captainfab
60-66 Nut
Re: Cal-Tracs
Here are a couple pics I saved of a members truck that is running Caltracs. I neglected to save his user name though.
So apparently they make them that will work on a pickup.
[quote=KQQL IT;3898843]
Old 04-03-2010, 09:35 AM   #18
fiddy9apache
Re: Cal-Tracs
mine are similar, they will run from the axle housing to a crossmember or from the ubolt plate to the frame. i might make a post today about them.
Old 04-03-2010, 07:21 PM   #19
team39763
Re: Cal-Tracs
I was told that they did make the split leaf setup for our trucks. I imagine it wouldn't be too hard for them to make some if needed. That's what I want for my truck next.
Old 04-04-2010, 10:33 PM   #20
shawnt
shawnt's Avatar
Re: Cal-Tracs
Good stuff Capt. I'm gonna go ahead and order some. Thanks for everyones help!
Shawn
Shawn
85 SWB
7.39 @ 93
Old 04-04-2010, 10:54 PM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Cal-Tracs
Im sorry if i wasnt clear. Last time i called cal-tracs, They didnt make a split mono leafspring for pick up trucks. my 73 wanted the light 3 leaf pack and both shocks pointed forward
Old 04-05-2010, 09:21 AM   #22
team39763
Re: Cal-Tracs
Are those homemade shock brackets you have bolted to the caltracs? If so, that's what I need to do. I was planning to have my shocks mounted behind the axle and vertical, but I may see if I can try that forward tilt like yours.
Old 04-07-2010, 12:37 AM   #23
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Cal-Tracs
Ya just angle iron bolted to the u/bolts, got the shocks back to a decent angle too.. A complete accident. But either forward or backward as long as there the same direction.
