03-30-2010, 01:13 PM | #1 |
Airconditioning
Getting ready to order a vintage air set-up any comments on do's and dont's would be appreciated.
03-30-2010, 06:47 PM | #2 |
Senior Enthusiast
Re: Airconditioning
Here's an older thread, which includes a link near the bottom to another related thread which may provide some interest:
http://67-72chevytrucks.com/vboard/s...ht=vintage+air
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
03-30-2010, 06:52 PM | #3 | |
Re: Airconditioning
deals on Vintage Air justin (805)485-0382 justin@scottshotrods.com |
03-30-2010, 08:28 PM | #4 |
Re: Airconditioning
do a search for COOLAIR. He installed a GEN II compact system. looked like it fit well.
I love the smell of lead paint! |
03-30-2010, 10:34 PM | #5 | |
Re: Airconditioning
they can ship out same day most of the time and they have direct bolt in units that anybody can put in. If you guys send me a e-mail justin@scottshotrods.com with your contac info I will call you back same day and give you all great prices and service. Justin www.scottshotrods.com |
03-30-2010, 11:15 PM | #6 | |
C10 CLUB Y QUE!
Re: Airconditioning
looking for a quote h4zed77@yahoo.com Last edited by Sick5; 03-30-2010 at 11:16 PM. |
03-30-2010, 11:18 PM | #7 | |
Re: Airconditioning
03-30-2010, 11:25 PM | #8 | |
C10 CLUB Y QUE!
Re: Airconditioning
03-30-2010, 11:31 PM | #9 |
Re: Airconditioning
I will have a total for you on wed if you can send me a e-mail so
I can send you over some prices for you on wed and are you looking for a 100% complete kit let me know in a e-mail if that is possible. justin@scottshotrods.com |
04-06-2010, 03:50 PM | #10 | |
Re: Airconditioning
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-07-2010, 06:23 PM | #11 |
Re: Airconditioning
Well I just ordered my ac from Mark (coolair on here) at vintage air, he couldn't have been more heplful with the process of what I need, BIG thanks Mark.
04-13-2010, 07:14 AM | #12 |
Re: Airconditioning
Well I got my Vintage Air unit in yesterday and took it all out to look it over, to make sure nothing got damaged in shipping, boy it sure looks intimidating, but I'm sure it isn't anything that I cant handle.
03-30-2010, 11:33 PM | #13 |
C10 CLUB Y QUE!
Re: Airconditioning
no problem will do
03-31-2010, 10:52 AM | #14 |
Re: Airconditioning
The Sure-Fit for the 60-66 trucks are for Chevrolet only as the GMC dash is different. I put a GEN II Compac in my 65 Chevy - it's a little more work/fabrication but in my opinion, it's worth it to get an all electric operated evaporator vs a vacuum system.
Let me know if you have any questions - Mark @ VA 1.800.862.6658 ext.111 |
03-31-2010, 12:05 PM | #15 |
Wide Eyed User
Re: Airconditioning
I have Vintage Air, and I believe mine is all electric. Make sure you upgrade your Alt. I have a 155 amp alt and with the stuff I am running (not just the air) i could prob use a 200. Just switching from Med fan air to Hi air it drops my charging .7 at idle and about .3 running.
I have to say that I am not sure if mine was specifically for my truck, so my comments may be off... things that I would like to see diff: I would like two seperate outlets for the defroster rather than having to use a Y connector. The air movement for the defroster is a bit weak IMO (see comments below). Also, It seems the controls are a bit cheesy. I already broke a selecter knob almost immediately and had to replace the entire head unit. Luckily they are only like $40.00 and luckily SoCal parts had one in stock (maybe that's why they are only $40). I barely touch them now to change the settings in fear of breaking another knob. I like the head unit from Dakota Digital but the price is almost as much as my entire gauge package was from them. Last, I would like to see a bit more air movement on high, as I only have three vents for the a/c and if I didn't have a single cab, it would be hurtin. I haven't been through a summer yet, so I can't tell if it's gonna hold up at 110. I have only had it going when it's been 80. With this being said, I am not sure any aftermarket a/c system is going to be great, but I haven't tried any other. For the price they should be. you can see head unit... as it was being installed...
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441 Last edited by DaddyMack; 03-31-2010 at 12:12 PM. |
03-31-2010, 02:19 PM | #16 |
Re: Airconditioning
DaddyMac - Just read your post and was confused about something - you have a Gen II Compac - it has two defroster outlets not one so you shouldn't need to Y the defrost duct hose. The Compac should have more than enough air flow - last summer in San Antonio we had 65+ days over 100 with high humidity and I ran mine on medium fan speed 90% of the time and was more than comfortable and the wife was too cold every-time she rode in it.
Make sure your duct hose is pulled as tight as possible to aid in air flow, also the rectangle vents are more restrictive than the round ones - I normally recommend a round vent in the corners and the rectangle in the middle. Also check the blower motor and that you have 3 distinctive speeds. You should see 35-40 degree vent temp out of the vents - so if you insulated your cab well, you should have no problem cooling your truck in Vegas. Let me know if you have any questions. Mark Tech Support Vintage Air |
03-31-2010, 04:03 PM | #17 | |
Wide Eyed User
Re: Airconditioning
Thanks Mark... I will pull it down and take a look this weekend if I have time. It may simply be blocked. I will double check. I will check the temp at the vents as well and I do have three speeds.
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441 |
03-31-2010, 08:52 PM | #18 |
Re: Airconditioning
Hey Mark, would a system like this cool a Suburban or would I need some sort of rear unit too?
03-31-2010, 08:56 PM | #19 |
Resistance is Futile
Re: Airconditioning
I have an old 'knee freezer' in my 'burb and it wouldn't come close to keeping up with summer down here. When I re-do it I will add a second blower in the rear area.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
04-01-2010, 11:14 AM | #20 |
Re: Airconditioning
DWC,
My first question would be how are you using the Sub? Are you going to have passengers all the way in the rear or just the front half of the truck? Without knowing the answer to the above question - I would recommend doing more of a Custom system rather than the Sure-Fit. I would look @ the Gen IV Magnum evaporator - this is our highest output system designed for large sedans and wagons plus it has the latest electronics to operate the doors and control the temp so it operates like a late model OEM system. We can use some of the items from the SFK to aid in install such as the defrost duct adapters, condenser kit, firewall block-off, etc. I think the Gen IV Magnum by itself, will work fine as long as you have the truck well insulated. You can always add a rear evaporator later if needed - it may be a little more hassle but if one evaporator is sufficient, it would be a lot cheaper. Let me know if you have any questions. Mark |
04-22-2010, 11:23 PM | #21 |
Re: Airconditioning
Yup - it is more time consuming than hard. A system designed for an application is for the most part a "bolt in" kit with very little fabrication needed. A custom system like OK is doing takes a little more planing out and think how you want the finished product to look - ie, smooth firewall, hidden lines, SS Braided lines, etc.
Hey OK - looking good!! If you think about it, call me next week - I have a question about your drier - (we are closed Friday the 23)........Mark |
04-23-2010, 12:49 AM | #22 |
Re: Airconditioning
Looks good OK....this is giving me some ideas
Togart '66 GMC 1500 '77 C-10 Scottsdale Big 10 |
04-23-2010, 09:00 AM | #23 |
Re: Airconditioning
Like Coolair said, it is pretty easy, just need to plan it out and not get in any hurry, its been almost 2 week since I started it, and I didn’t want to rush anything and make any mistakes.
04-29-2010, 12:02 AM | #24 |
Re: Airconditioning
On all vintage air products we have some long deals for all board members here please call us or e-mail for quates or orders
justin@scottshotrods.com (805)485-0382 |
04-29-2010, 03:24 AM | #25 |
Re: Airconditioning
hey guys- i noticed a couple of yall are still installing fittings the old way of indexing & taking them to get crimped. this is what i use. air-o-crimp. check out the web on them. they work! also you can remove them & use them over. only need the plier tool to install. the ones i use have an o-ring on the barb that fits right under the clamp. they never leak!
http://www.atcomail.com/products/airocrimp.htm enjoy! andy |
