04-01-2010, 10:00 AM | #1 |
Will a 70 2wd Cube tranny crossmember fit 1/2 ton?
found a guy with a 70 2wd cube with probably 1 ton axels (I'm guessing) ....will the auto tranny crossmember fit my 1/2 ton?
If your not living for something, your dieing for nothing... |
04-01-2010, 10:23 AM | #2 |
Re: Will a 70 2wd Cube tranny crossmember fit 1/2 ton?
What's a cube? The only Cube I know of is that ugly a$$ Nissan.
04-01-2010, 10:25 AM | #3 |
My guess is its a C30 with 2 wheels in the back instead of the 4 and a cube box in place of a flatbed or regular box. Like a delivery truck.
If your not living for something, your dieing for nothing... Last edited by eastcoastcivil; 04-01-2010 at 10:26 AM. Reason: added more info |
04-01-2010, 10:30 AM | #4 |
If it's a 1 ton, then it probably won't work, the frames are taller on them than a 1/2 ton.
04-01-2010, 10:31 AM | #5 |
I actually need it for my 3/4 ton....would that work? are 3/4 ton and 1 ton frames both taller than 1/2 ton?
04-01-2010, 11:58 AM | #6 |
easy way to tell is measure both
