04-01-2010, 11:23 AM | #1 |
Jeep Wrangler Fuel Filler Door Question
I'm going to relocate my fuel tank using the LMC Blazer tank. I've been searching on here and have found a bunch of ideas. I was hoping not to have to do any metal work, so I was thinking about using a late model Jeep Wrangler filler neck and after market access door. I am searching junk yards for Jeep Wranglers so I can get all of the guts for this installation. All I will have to do is drill a hole in the bed side. Any thoughts on this?
-TJ
1970 Chevy Custom C/10 Dark Bronze & White, 406 C.I. SBC, Edlebrock Cam, Intake, TH350 Trans with cooler, Headman Headers, 2.5" dual exaust with 28" glass packs, 3:73 gears, Original Oak bed, Pace Edwards Roll Top Toneau Cover, Resounds Bluetooth Radio, Chevy rally wheels, 265/75R15 General AT2's |
04-01-2010, 12:04 PM | #2 |
Project Junkie! Fishing Poor!!
Re: Jeep Wrangler Fuel Filler Door Question
I don't think that those type doors look good on these trucks. Maybe I am old fashioned, but you asked for opinions.. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
04-01-2010, 01:20 PM | #3 |
both those look to b mounted on flat panels check your bedside with a straight edge and see ifin its flat
04-01-2010, 01:22 PM | #4 |
Opinions are always welcome! That is my biggest fear is to take away from the stock look of the truck, but this seems like the easiest/most accessable way of getting fuel into the tank without doing a bunch of body work. I am going to think about putting it behind the marker light, that seems the least evacive of the ideas I've seen on here.
04-01-2010, 01:38 PM | #5 |
The PO of my truck put in a filler in the bedside from a late model truck and i have often wondered about the same application you are looking at. Another option would be an H2 fuel door. I am surprised nobody has done this yet. If so i would like to see a pic. You can pick up the Wrangler fuel fillers pretty cheap on line. The curve of the bed is the tricky part like the previous post said. Wranglers are FLAT. I would not want to distort the bed side for a fuel filler.
1969 Chevy K20 Longbed |
04-01-2010, 02:12 PM | #6 |
Grandpa in the rustmobile...
I got a fuel door from a mid 90's chevy fullsize. I may do the sidemarker filler still. Do you have to cut the inside of the bed up? IS THERE FABRICATING INVOLVED? Or is it just being nifty with your hoses...
that sounds funny..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-02-2010, 02:09 AM | #7 |
Big Red - Now its a SWB!
Need advise on being nifty with your hose huh? Better watch out that can get you in trouble!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
04-01-2010, 09:40 PM | #8 |
I am not sure about the filler in the marker light but the inside of my bed has a notch for the filler neck with the later model filler. The side marker looks like the same elevation but i have not seen pics of that done yet. I am sure there is a thread somewhere on the board.
04-02-2010, 02:14 AM | #9 |
If you like the idea of the Wrangler filler... forget about the outside of the bed... put that puppy on the inside wall of the bed.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-02-2010, 02:35 AM | #10 |
I Like Mine With No Shine!
I picked up one of these. For a Hummer H2. I like it because it doesn't have the chrome rivets or hardware on the trim ring edge. It secures from the back side. And it is lockable. Its made of billet aluminum too. If I end up using it, I think it will look good mounted on the outside of the bed or inside. Just my 2 cents though.
Michael 1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day) 2006 GMC Sierra Crew Cab 4x4 1969 Lincoln Continental Coupe Project FOR SALE http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 1981 Honda CM400 C Bobber SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
04-02-2010, 03:03 AM | #11 | |
fan of "Butters" Stotch
also, I have seen somewhere on here where it was behind the marker light (as mentioned earlier) Very trick!
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again Last edited by tapeworm; 04-02-2010 at 03:04 AM. |
04-02-2010, 04:57 AM | #12 |
I can understand not wanting to change the stock apperance of the truck, I'm the same way. I went with a 69 Camaro tank that fills behind the liscense plate. As you can see it sticks down a little below the bumper, but you would have to be looking for it to notice.
1969 C/10 Longbed undergoing rebuild. Old Chevy's Never Die, They Just Rust Around The Edges |
04-02-2010, 08:32 AM | #13 | |
Thanks for all of the input!
