Heater Box Mod?
I'm putting in a BBC in my 64, so I'm going to need every inch I can get! BUT I'm looking at that heater box, it's sticking way out into the engine compartment. Anybody seen, heard, or know of a modification to put it under the dash and out of the way?
Re: Heater Box Mod?
I used the heater box from 60-62. I put right angle elbows on the core inlets. Then ran the lines along the frame rails and up into the cab. All of it is inside the cab. That gave me a clean firewall.
C10 CLUB Y QUE!
Re: Heater Box Mod?
got any pic
60-66 Nut
Re: Heater Box Mod?
You could probably retrofit a recirculating heater from a '60-'63 into your '64. They are completely under the dash, but they don't work as well as the Fresh Air heater....aka. the Deluxe Heater. There's one on ebay right now.....http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
BTW the Deluxe Heater won't interfere at all with a big block.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 04-03-2010 at 02:00 AM. |
Senior Enthusiast
Re: Heater Box Mod?
Here's a shot of what a recirculating or economy heater looks like from the engine side of the firewall. The only thing showing are the two heater hoses and a couple of attaching bolts.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#6 | |
Re: Heater Box Mod?
I would love to axe the under hood heater also. A couple questions for ya: 1.0 With the economy heater do you have problems with the windshield fogging over on rainy humid days? 2.0 Am I correct in assuming the economy heater doesn't provide any outside fresh air mixture into the heating mix? Wonder why a guy couldn't cut into the cowl vent from inside the truck, thus pulling fresh air in without having the heater on the firewall? You know me, always ready to cut something up! ![]() Last edited by lakeroadster; 04-06-2010 at 07:27 AM. |
#7 | |
Senior Enthusiast
Re: Heater Box Mod?
In high humidity/heavy rain the heater has a harder time keeping the center completely clear, but again cracking the vent window and running the fan on high speed eliminates the fogging. Perhaps the 1960 fresh air heater I had never worked correctly, but it didn't provide any noticeable improvement in defrosting ability over the economy heater. My truck came stock with no heater, and a deluxe fresh air model was the first heater I installed. It chronically smelled like antifreeze in the cab, even though everything (core/seals/gaskets/hoses) in the system were new and there were no detectable leaks. The smell is why I got rid of the fresh air heater, and the econo heater has never had an odor problem - so lack of stink was more important to me than heater/defroster capacity, and I was driving 36 miles each way every day for 9 years. 2.0 - Correct there is no fresh air intake with the recirculating heater. If a person was creative enough with sheetmetal ![]() In my search for a heater that would actually function in a northwest winter, I tried: 1. Fresh air 1960 oem unit (smelled). 2. Old Air A/C-heater system (completely ineffective). 3. An electric van auxilliary heater (useless). 4. A Vintage Air street rod heater (inadequate heat and direction control). 5. A Flexalite Mojave heater (decent heat, no direction control). Of the last 4, the only one that did any good at all was the Mojave heater mounted on the floor between the seats. It kept my feet warm and nothing else. The econo heater doesn't provide performance of a modern heater/defroster, but it worked well enough to drive the truck everyday in the winter, and now that it's retired to hobby duty I'm glad to have it instead of the fresh air breadbox on the firewall. Good luck with whatever you decide to do.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 04-06-2010 at 05:15 PM. |
Re: Heater Box Mod?
Mark,
Thanks for the detailed breakdown, very informative. |
#9 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Heater Box Mod?
#10 | |
Re: Heater Box Mod?
Thanks for the heater info, I'm sold on the heater you used. I'm going to try to find the heater could you tell me what to look for (years, heater control 2,3,or 4 handel) any thing else you can think of to help me in my search. Thanks Keith |
Re: Heater Box Mod?
Here is mine out of the truck...
![]() Firewall view... ![]() I will warn you though, mine is all rebuilt with new core and blower motor and the performance of it absolutely sucks. Even temps in the 40s it's not near enough to make the cab comfortable.
Re: Heater Box Mod?
Since you live in Bakersfield CA you probably could deal with the ultra rare "heater delete" option.
![]() Here is a link to a couple of small heaters used for Hot Rods. About as basic and simple as it gets. http://www.southernrods.com/categori...ern-air-1.html Last edited by lakeroadster; 04-03-2010 at 07:47 AM. |
Re: Heater Box Mod?
When you do the "heater delete" option, do you simply loop the coolant line? just take the heater out of the circuit?
'64 Corvair Ragtop '66 C10 Stepside "The oxen may be slow, but the Earth is patient" |
1# Drobmember in Germany
![]() Join Date: Aug 2008
Re: Heater Box Mod?
Pat |
#15 |
Senior Enthusiast
Re: Heater Box Mod?
There was a time when I ran no heater in my truck. I simply put pipe plugs in the intake manifold and water pump eliminating the hoses completely, and reinstalled the factory block off plates on the firewall.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 04-05-2010 at 07:23 PM. |
#16 |
Airport Bum
Re: Heater Box Mod?
I would imagine you would have more of an issue with the dual master and brake booster with a BBC.
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
#17 |
Resistance is Futile
Re: Heater Box Mod?
Nope, fits no problem.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#18 | |
Re: Heater Box Mod?
#19 |
Re: Heater Box Mod?
I have the deluxe heater and dual master power brakes with a bbc in my 65.I am using the stock height valve covers.No clearance issues at all and I can remove the valve covers fairly easily in the truck.
65 c-10 swb,bbw,step,402/t350,sold!! 1979 c10 Silverado,250,auto,gonna have a 3/5 drop,and twice pipes!Sold Bought the wife a 84 gmc short step |
#20 |
Re: Heater Box Mod?
Same here. Only issue I have is that a 13-14" air cleaner hits it. I've got a K&N velocity stack with a 5" tall filter that fits great.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
#21 |
Senior Enthusiast
Re: Heater Box Mod?
Back when I commuted every day I'd always change my 160 degree summer thermostat to a 190 version for the winter months. Having 30 degree warmer coolant made a big difference. Didn't think to mention that.
#22 |
Re: Heater Box Mod?
I got rid of my deluxe hater and installed a vintage air unit and it has a great blower and heater in it.
