04-03-2010, 02:55 AM | #1 |
Leaf to Coil Shock Mount - How to hook em up?
Changing from leafs to coils on a '72 Cheyenne Super LB, using the CPP Totally Tubular kit ( http://www.classicperform.com/Store/.../6372TRS-K.htm). Despite the advertised picture and explanation of what I'm doing to the rep, there is nothing in the kit to mount the upper shocks to. Can I use the shock mounts from an original coil set up off another truck? Are there after market mounts? Thanks for the help.
'72 Cheyenne Super LWB 350 '70 C20 '55 Cameo |
04-06-2010, 09:45 AM | #2 |
Happy to be here
Re: Leaf to Coil Shock Mount - How to hook em up?
Anyone?
04-06-2010, 09:59 AM | #3 |
Java Mechanic
I don't know the details on a leaf spring truck.
On a coil spring truck the shocks (in stock form) mount to tabs attached to the crossmember that is over the axle. It looks like that kit has fairly standard shock relocators for that purpose but I don't know the stock upper mount location for a leaf spring truck. If you have a picture of that part of your truck we should be able to noodle it out (or maybe someone who atually knows will drop by with an answer!)
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
04-06-2010, 11:21 AM | #4 |
Beer Drink'n Knuckle Dragger
are you talking about the upper or lower shock mount?
i know you can either fab your own or diy4x.com has a bar that you can order to place your own, but it's more geared towards 4x4...might be able to make something like it work
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US - 67 GMC Long-Wide 350/SM420 My BACON Wrapped Meatloaf Recipe |
04-06-2010, 11:51 AM | #5 |
Have you spoken to Jeff specifically. Perhaps he could advise. On their image online they show a piece of tube steel spanning between the frame rails with the upper mounts but I can't remember if that piece is 73-87 specific.
04-06-2010, 06:03 PM | #6 |
it says to call and that they can make them custom length or at least work something for you...worth a shot
04-08-2010, 01:11 AM | #7 |
Thanks all for the input. Jeff and CPP have been no help despite knowing what I was trying to do when I dropped big buck on the kit. Seems like a pretty big detail to have left out. The bar that the upper shocks mount to in the ad doesn't exist. They put it in for the ad only!?!?!?!? FYI, the cool blue color of the kit in the ad doesn't exist either. It ships a not-so-cool grey. I'll try to get some pictures posted to better explain my problem. Thanks again.
04-09-2010, 05:25 PM | #8 | |
04-08-2010, 07:37 AM | #9 |
Java Mechanic
I would think you could just scavenge the crossmember off a coil spring truck or make one.
I'm in the process of restoring my frame. I just put that part back in. You can see one of the shock mounts sticking out below the crossmember in this picture. If it helps.. I could get more detailed pictures tonight when I get home.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... Last edited by panhandler62; 04-08-2010 at 07:38 AM. |
04-08-2010, 09:48 AM | #10 | |
I wouldn't expect CPP to supply these in the 'kit' since they aren't needed for guys w/coil trucks that purchase the CPP coil suspension drop kits (which is what the Totally Tubular kit is). Did the kit have the shock relocation brackets?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-08-2010 at 09:49 AM. |
