04-03-2010, 06:19 PM | #1 |
BlahBlahBlah
Motor mount pics for Livrat
Hey Mark thanks for stopping out today. I turned the place upside down and found those motor mounts we were talking about.
I bought em here off the board quite awhile back. I do remember asking (don't remember who now) if these were correct for the swap and was told yes. Let me know what you think.
04-03-2010, 07:19 PM | #2 |
Re: Motor mount pics for Livrat
Your workbench is too clean. You need some tools and some random clutter. I could help you out with the clutter, my garage has more than enough.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
04-03-2010, 07:50 PM | #3 | |
BlahBlahBlah
Well that will suck if these dont work. Ive thrown away way too much money putting parts together for the panel.
04-03-2010, 07:19 PM | #4 |
Member #1049
Mark, Took a look through all my pics and even Al's post on the Caddy install, Could not find out if those are the exact ones needed or not.. I guess we will find out when we test fit the 500... I can bring 2 other styles just in case..
04-03-2010, 08:17 PM | #5 |
Watch out for your cornhole !
73-87 frame mounts in that picture.
04-03-2010, 08:25 PM | #6 |
BlahBlahBlah
Thanks for the clarification. I wasnt sure on the year of these and I should have called them frame mounts not motor mounts.
04-03-2010, 08:33 PM | #7 |
Member #1049
Kevin.. thanks for the clarification.. I totally forget to mention/post that..
I have found 4 different versions of the 73-87 Tower/mounts.. I do know that the ones pictured are not the ones to use in a Big block chev install in a 67-72 truck.. (they will make the engine sit up too high in the front) I do not know remember if those were the exact style we used in a Burb/Caddy install I did a couple years ago. |
04-03-2010, 08:28 PM | #8 |
Mounts, stands, all the same to me. I just wanted to point out that they were 73-87. A lot of folks get them confused with 72 only big block mounts.
04-03-2010, 08:41 PM | #9 |
BlahBlahBlah
Guess I wont need to drag out my 72 big block towers then. Im checking out threads with Caddy swaps now.
