Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 04-03-2010, 07:31 PM   #1
1970FathomBlueMalibu
Difference in ride height for 2WD vs. 4WD?
Taking different tire heights out of the equation.......is there a difference in ride height for the 2WD vs. 4WD trucks?
I'm curious if 2WD models' (mine's an '08) suspension sits the truck lower, so that tire clearance might be an issue, if I went with a bigger than stock tire size.
Kind of a confusing question, but I don't know how to spit it out much differently today.
1970FathomBlueMalibu is offline   Reply With Quote
Old 04-03-2010, 07:55 PM   #2
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Re: Difference in ride height for 2WD vs. 4WD?
I know the previous gen trucks (99-06) the 4x4 sat higher. My 07 classic with just keys cleared my 33" nittos.
The new trucks have much bigger wells and I didn't notice a huge difference between my 09 2x4 and my buddies 09 4x4.
What size tire do yo want to run? I am running a 2.5" spacer and i have zero rubbing with the same 33's.
Cole Trickle is offline   Reply With Quote
Old 04-05-2010, 10:45 AM   #3
I would like to try a set of 285/70/17's. I know that 265/70/17's will fit with a decent amount of room. This is for the Mickey Thompson Baja ATZ Radials.
I'm not using any spacers. Is that something I need to look into?
I just want to make sure that there is no issue with a full turn of the wheels or really any fitment issues at all. I really don't want to put on a lift kit for this truck, since it's a 2WD. I just have fairly rough terrain to go over every day, since I live in a rural area, plus I'd like to fill up the wheelwell as much as I could.
33X11.50R17 is the advertised specs and 32.8" diameter, as measured by Mickey Thompson.
Section width is 11.4".
Tread width is 9.1".
Thanks!
Old 04-05-2010, 01:40 PM   #4
Cole Trickle
C-10 Club Member
Thanks!
Your going to need a spacer lift or your going to trash the tire/fender with those tires.
My tires are very similar in dimension and the 2.5" spacer works well(no rubbing). I installed it myself in about 1.5 hours in the garage.
http://www.ccmoffroad.com/shop/index...ct_detail&p=23
Old 04-05-2010, 05:47 PM   #5
So, I'll need a lift kit? How and where do the spacers install? Any tricks to it? What brand did you use and how much did it cost?
If I have to lift it, I might just get the 265's.
What size and brand tires are you using?
Thanks for your help.........
Old 04-05-2010, 05:51 PM   #6
Cole Trickle
C-10 Club Member
Your gonna have to lift it to clear the tires you are shopping.....
I am running 285/70/17 Nitto Terra Grapplers
I got the spacer from the link above......(Less than $100 shipped)
Install was pretty straight forward with there instructions. The spacers go on top of the factory springs.
Old 04-06-2010, 08:53 PM   #7
I have a 4.8 with the 4 speed auto and 3.23 limited slip. Man, I wish I had more motor. And gear.
Old 04-08-2010, 02:36 PM   #8
LEEVON
Moderator
LEEVON's Avatar
same here, and my tires are a bit taller than stock. mileage sucks and you find yourself going 85mph all the time on the highway. I'm planning on a cam and 4:10 gears to wake it up.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-08-2010, 07:05 PM   #9
I'm actually only going with tires at the moment. I don't particularly care for the factory chrome work wheels, but I don't have enough scratch to replace them right now.
If I did, I'm thinking the coated Torque Thrusts look kinda cool. I'd like to see more pics of 07+ with aftermarket stuff, tho, to make a choice.
My brother is a GM tech, so he can do all the tuning for tire size and pressures, if it's needed.
I have the 3 year/36K warranty. So, with one more year left on that......well, I'll be looking at gears around this time in 2011.
Oh.........I had a flat today, just as I was getting home from work. So, that's 2 of them that's done this. I have just under 28K on them. They look like chewed bubble gum at this point.
I haven't decided if I'm about to try to plug it or let the factory spare hit the ground for the first time.
BTW, LEEVON, I see you're from Arkansas and so am I. What part?
And who's making aftermarket cams for these 4.8's?
Old 04-07-2010, 09:02 PM   #10
I just ordered the 2.5" leveling kit today. Starting to get pretty excited about doing some things to my truck, since this will be the first things I've done in the 2 years I've owned her.
BTW, Cole, did you have GM custom-make a program for your truck, after changing the tire size?
My brother doesn't think it's necessary with these tires being 2.5"- 3" taller, but I'm on the fence about it.
He can easily modify the tire pressure limits, if I run anything different with the new treads.
What kind of pressures do you run in yours?
Old 04-07-2010, 09:52 PM   #11
Cole Trickle
C-10 Club Member
I havent done anything tuning waise at this point. The speedo is probably off by 5-7 mph at freeway cruising speed.Truck drives and shifts fine...plus the good news is its showing less mileage being put on the odo.
You will need to swap your tire pressure sensors to the new rims/tires. it tells you how to manually re set them in the manual. if you need any help let me know.
There are a couple options for tuning....easy hand held (diablo sport.superchips) more advanced you could get a custom tune with hp tuners.
Congrats on the upgrades.....did you pick wheels/tires yet?
Old 04-08-2010, 07:33 PM   #12
Check that. I have TWO flats. Geez. Now things are getting ridiculous.
Old 04-15-2010, 12:56 PM   #13
I received my leveling kit from CCM last night. They look to be very quality pieces.
I'll be installing them, along with new 285/70/17 Mickey Thompson Baja ATZ radials, in a week and a half.
I'm pretty excited.........
Old 04-15-2010, 05:00 PM   #14
Cole Trickle
C-10 Club Member
Congrats....
Post some pictures when your done. It should look alot different
Old 04-16-2010, 01:55 PM   #15
I'll definitely try to post pics.
What entailed putting this leveling kit on? The instructions that CCM sent me say it's for a "lift kit" and not a "leveling kit" and it looked to be a lot more work than I anticipated.
I just know that they discern between the 2 kits on their website, so I'm really thinking they sent me the wrong instructions.
Old 04-16-2010, 02:16 PM   #16
Cole Trickle
C-10 Club Member
It was a single page instruction sheet....like 1-20 (take your time its easy... do what they say and your golden. I tried to speed up the install and skip some steps and had to take the spring back out and do it the way they said)
Pretty easy actually. I think I tossed the instructions or I would scan and email them to you. Give them a buzz and see if they can email or fax you the correct sheet.
