04-03-2010, 09:15 PM | #1 |
Next project: 1970 K10
Doh! Which trans cooler lines are which on the radiator?
I pulled the tranny cooler lines out of the truck and forgot to note which one went where before I yanked 'em out.
So what I need to know is, on the radiator, which is the inlet and which is the return (top/bottom). Thanks!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
04-04-2010, 12:04 AM | #2 |
BAD BOW-Silverado XST
Re: Doh! Which trans cooler lines are which on the radiator?
04-04-2010, 12:27 AM | #3 |
Those are on the trans, I need to know which is which on the radiator.
04-04-2010, 12:46 AM | #4 | |
OK, finally found this:
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 04-04-2010 at 12:47 AM. |
04-04-2010, 10:49 AM | #5 |
It'd be alot cooler if you did
^^ sounds right... I've made that mistake a few times.
04-04-2010, 10:53 AM | #6 |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
04-04-2010, 02:47 PM | #7 | |
04-04-2010, 04:22 PM | #8 | ||
04-05-2010, 03:03 AM | #9 |
Why does it matter? The radiator is simply a heat exchanger. Fluid loses/gains heat to/from the ambient air/coolant. Direction is not that important.
04-04-2010, 11:34 AM | #10 |
Bottom is in Top is Return
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
04-04-2010, 02:06 PM | #11 |
Yup, just think about water flow. Where is the coolest water entering the engine?
04-05-2010, 08:20 AM | #12 |
which lines are which on the 4l80e? they are set-up front and back not top and bottom. thanks guys
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
04-05-2010, 10:36 AM | #13 | |
Front: Cooler feed/out
04-05-2010, 06:44 PM | #14 |
thanks Bob! i'll be doing this real soon bookmarked!
