04-04-2010, 10:26 PM | #1 |
bed bolt shopping?
wheres a good place to look at for bed bolts to assemble my longbed.. i am swapping floors out to a different steel floor since mine was all holey... so i need new bols going from the sides to the floor the front panel and all.. also i want new bed to frame bolts.. i looked at a place and started tallying it up to over 100-200 bucks.. is that right?
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
04-05-2010, 12:08 AM | #2 |
Too many toys,not enough money
Re: bed bolt shopping?
Might be cheaper to try your local hardware store. I've had to correct some mistakes from one of the big resto co's, and found buying in bulk much cheaper, just make sure all the bolts are the same.
Looking for all Montana members. PM me or send friend request.http://www.67-72chevytrucks.com/vboa...36#post3813336 |
04-05-2010, 04:37 AM | #3 |
Watch out for your cornhole !
Tractor Supply sells carriage bolts for about 3 bucks a pound. You should be able to get all of the bolts, nuts, and washers to do the entire bed for well under 20 dollars.
04-06-2010, 09:47 AM | #4 |
04-06-2010, 10:14 AM | #5 |
You could make it work, The only difference it the offest washers and bolts for the main bed mounting, I had a set of those for sale on the parts board...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
04-06-2010, 02:28 AM | #6 |
I second Tx Firefighter on that. Also if you want chrome or stainless you can try ACE as they do stock some.
04-06-2010, 07:18 AM | #7 |
Anybody know off-hand what lengths, sizes, and amounts?
I'm in the same position. I have one disassembled and want to get to that this spring.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
04-06-2010, 09:25 AM | #8 |
I'd also like this info. If any one is in the process of putting a bed togeather right now please post the info.
Doug Looking for a 67-72 short bed driver..... |
04-06-2010, 09:35 AM | #9 |
count and measure is that soooo difficult?????
04-06-2010, 09:42 AM | #10 |
Not difficult, but If one person has allready done the work. Why not share the info with the rest of us and save us some time? Plus the bed I have is in peices so I don't have any of the original hardware to compare.
Doug Looking for a 67-72 short bed driver..... Last edited by m6z; 04-06-2010 at 09:43 AM. |
04-06-2010, 12:53 PM | #11 |
ya i dont have the bolts to measure i either cut and drilled them out or i just kept tightening the bolts until they broke off then i just left them in the grass..
04-06-2010, 12:57 PM | #12 |
Sucks to mow your lawn I'd bet.
04-06-2010, 01:00 PM | #13 |
You should be able to get a rough idea by using some old bolts that you have lying around... Most of the assembly bolts are 3/8 i think and the mount bolts are 7/16 or 1/2 at the most. I'd run to Tractor Supply, pick up a few grade 2 bolts of different lengths and test them out... then buy what you need. Only cost 50 cents to pick up a handful of choices.
04-06-2010, 02:18 PM | #14 |
Wide n'Low
There was a thread with pictures and lengths for each position around here somewhere..
My bad, the thread I mentioned was for Blazer body mount bolts..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired Last edited by Twisted78SS; 04-06-2010 at 02:27 PM. |
04-06-2010, 05:18 PM | #15 | |
04-06-2010, 07:10 PM | #16 |
Question and answer both right there. I can do a whole lot of measuring to save some money. On my junk, I actually ordered a basic zinc plated kit from Mar-K for 50 bucks. I figure I could have assembled my own hardware for about half that, so some convenience for 25 bucks was worth it to me.
04-06-2010, 07:45 PM | #17 |
ha ya tx i dont mow my lawn my 11 yr old brother does so he will have a surprise maybe haha.. its rained so they might of sunk in the ground
09-20-2010, 02:45 PM | #18 |
I used 4" 3/8 zinc coated bolts nuts & nuts from TSC this weekend. 8 of them worked fine for my '67 1/2 ton with steel floor.
$5 |
