Old 04-05-2010, 07:20 PM   #1
sixbangr
sixbangr's Avatar
manual shifter getting stuck
shift linkage gets hung up and won't shift out of low. any fix for it? 3 on the tree.
1961 Apache short step.
sixbangr is offline   Reply With Quote
Old 04-05-2010, 07:32 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: manual shifter getting stuck
This why so many old 3 speeds ended up with floor shift conversions. The original design wasn't all that bulletproof to begin with and over time as the parts wear they are prone to getting stuck. This older link may help if you decide to try and rebuild the linkage and need bushings, but it's usually the components in the shift mechanism on the column that wear out:
http://67-72chevytrucks.com/vboard/s...d.php?t=291859
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-05-2010, 09:04 PM   #3
sixbangr
sixbangr's Avatar
just found the upper bushing that is missing on mine. Place called Bob's Chevy trucks. $2.88
Old 04-06-2010, 01:35 AM   #4
collins10672
collins10672's Avatar
i think obsolete chevrolet sells all of the grommets for the three speed column shifters.on the column section and also where it hooks up to the transmission.google obsolete chevy and you will find their website.do not know if they are listed online or not,but they do have them in their catalog.good luck
collins10672 is offline   Reply With Quote
Old 04-06-2010, 06:07 AM   #5
Shaky
Six in a row makes it go...
Shaky's Avatar
I had a '68 Chevy Biscayne that I got with 26,000 original miles. It had 3-on-the-tree. I kept the linkage greased regularly. Never had a problem - shifted like glass...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-06-2010, 07:15 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I always rebuild the linkage with new bushings and never have any issues.
Classic Parts sells everything you need for well under 20 bucks.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-06-2010, 01:56 PM   #7
Rogue
Airport Bum
That is theft prevention.
Well just having a 3 on the tree is good, since most people can't/never drove one.
My truck was like that for years, and only I could drive it.
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
