04-06-2010, 04:30 AM | #1 |
is your transmission tail shaft centered between your frame rails? I need a favor! :)
I am doing a 6.0 swap and the engine looks to be very slightly crooked. the tranny tailshaft is about .5" to the drivers side.
can anyone pull a tape across their tranny tailshaft and see if it is centered between the frame rails? thanks!!!!!!!!!!
WTB 73-87 SWB fleetside bed!! 85 C10 6.0 project 69 camaro ls1 / t56 90 mustang lx 75 bronco injected 351w |
04-06-2010, 10:03 AM | #2 |
Happy to be here
Re: is your transmission tail shaft centered between your frame rails? I need a favor
Anyone?
04-06-2010, 02:32 PM | #3 |
Formerly- 1972SuperCheyenne
I just looked and mine is centered. The engine mount stands and trans crossmember bolts have a little play if you need to adjust. Just take the frame stand bolts loose and shift the engine and trans where you need it to be and bolt them back down.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
04-06-2010, 02:38 PM | #4 | |
I am looking for a SBC one with oem type mounts. i jsut want to be 100% sure before i finish my mounts. i think i found some long tubes that will work but i have to do a little more work to post up results.
04-07-2010, 04:10 PM | #5 |
Next project: 1970 K10
Mine was centered pre-swap, and is again centered post-swap.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
04-07-2010, 04:35 PM | #6 |
wouldnt make a differance if it was pre swap or lsx should be center!! mine is!!! what mounts do you have the slotted type???
78 C-10 5.3 LSX -4L60E |
04-07-2010, 06:23 PM | #7 | |
My mounts may end up being totally custom. i want the engine set back as far as possible in the bay. right now i have the carshops mounts and have made the engine stand mod but i am not satisfied with the fit. the more weight i can get to the back the better i will feel
WTB 73-87 SWB fleetside bed!! 85 C10 6.0 project 69 camaro ls1 / t56 90 mustang lx 75 bronco injected 351w Last edited by SatisTraction; 04-07-2010 at 06:24 PM. |
04-07-2010, 07:47 PM | #8 |
BMW & ASE Master Certified
I made my own mounts, and Im pretty sure mines centered. I couldnt imagine why it would be angled unless somethings not right upfront...
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
04-07-2010, 08:41 PM | #9 |
dont really matter if it's centered that's what ujoints are for// many many cars came off assembly lines with off centered drivetrains and many millions of miles down the road few people ever knew
04-07-2010, 09:06 PM | #10 |
LOL, that is right. many engines are not centered between the frame rails.
04-07-2010, 09:34 PM | #11 |
I know mine is a swap but I am using the factory mounts. Hope you get yours figured out.
04-07-2010, 09:39 PM | #12 |
i dont think .5 will matter... for example I just went and checked out a guys new rock crawler he is building and its 4 wheel steer... the rear driveline sits at a crazy angle vertically and horrizontally so I wouldnt worry about it
