![]() Join Date: Feb 2010
Alignment shop methods
One shop said they use a machine and do a four wheel alignment and another said they put the truck on a hoist and hang things from the upper ball joints and I suppose other places to take readings to determine whether anything is needed.
Is one method preferable to the other?
Old Smokey: 85 GMC 3/4 ton long bed crew cab originally a 5.7 gas engine now with an 84 6.2 with a 92 serpentine belt system, a banks sidewinder, torque converter, and a shift kit. I bought her this way from someone handy - and now am trying to figure out how all this truck works. The Old Smokey project: http://67-72chevytrucks.com/vboard/s...d.php?t=390518 |
97' Tahoe 2dr/2wd
Re: Alignment shop methods
I use a Hunter alignment machine...
http://www.hunter.com/pub/product/al...947T/index.htm the machine at our shop is very similar to this one....targets mount on each wheel to determine the current alignment angles... |
I use a hunter four way machine. once the truck is lifted it uses a laser system off each wheel that goes to a central computer. ill post pics tomorrow. it works great!
oops. didnt see your post tommie. we use the same machine. its great.
i work at a toyota dealship and we also us the hunter equipment..... its a joy to do an alignment that way honestly
BMW & ASE Master Certified
seriously, hang something from the underside.. seriously?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Yes. The fellow said there is a slot on the upper ball joint that something fits into.
Next project: 1970 K10
LOL, the last time I did an alignment, my machine was a Hunter D111!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
97' Tahoe 2dr/2wd
its a pendelem.
Just thought you guys may want to see this site I came across:
http://www.carcraft.com/howto/48938/index.html It explains it pretty well and has some good pics and diagrams. |
97' Tahoe 2dr/2wd
that's what I would do to get it close enough, so I could take it to an alignment shop....
I just finished off my front end last night, in the pouring rain, and slapped on the new rims and set it down. Turns out it's positive cambering on one side, negative on the other, and the tie rod ends need to be adjusted. I found that article and figured I would do just what you said, tommie. That should get me close enough to not screw up my tires on the way over to a shop.
Thanks for posting that. Wish I'd known how to do that earlier. Just wobbled over to the alignment shop where my truck was off their measuring scale on alignment. They fixed everything, but the damage done driving around before I got it there has cost me two tires.
