Old 04-06-2010, 07:18 PM   #1
tim21391
tim21391's Avatar
cam choices?
so i am having troubles maybe thinkin i have a flat lobe on my cam.. what would be a great cam and lifters to give me that loping sound where it cuts it off and makes it sound like dying and what not
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-06-2010, 07:35 PM   #2
LONGHAIR
Re: cam choices?
Are you aware that you can't "just replace" a bad cam and put it back together? The entire engine must be removed, stripped and cleaned. The particles from the "flat cam" and the mating lifter will have spread through everything. The oil filter cannot handle that kind of volume and will begin to by-pass.
If you just R&R the cam and lifters, it will fail again.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-06-2010, 07:37 PM   #3
tim21391
tim21391's Avatar
Re: cam choices?
well my theory is i have a bad rocker and a bent rod from mis timing.. so fix the head and maybe cam and lifters if thats the problem
Old 04-06-2010, 07:54 PM   #4
joeelutz
joeelutz's Avatar
Re: cam choices?
I've never heard it described quite like that. I would recommend changing to a roller cam setup. Today's oils don't have the zinc content that flat tappet cams need. If you do go back with a flat tappet cam, be sure to use zinc additive.
joeelutz is offline   Reply With Quote
Old 04-06-2010, 08:03 PM   #5
jimmq
jimmq's Avatar
Re: cam choices?
Rebuild engine!!?? I had a 77 stepside back in HS with a bad cam. Replaced it and beat the you know what out if it for 4 years. Ran when i sold it.
jimmq is offline   Reply With Quote
Old 04-06-2010, 08:05 PM   #6
tim21391
tim21391's Avatar
Re: cam choices?
engine only has about 15,000 miles on it.. so its almost im thinking something just came loose.. but i think im running hydraulic lifters
Old 04-06-2010, 10:14 PM   #7
capev86
Re: cam choices?
if i'm gonna change out a valvetrain......it will be full roller and on a truck it will be nothing but an RV grind. i want smooth idle, tons of vacuum for the brakes and awesome throttle response and max low end torque so i can enjoy it on the street. in a "car" not towing anything, something a bit more peaky would be fun!
capev86 is offline   Reply With Quote
