04-09-2010, 11:06 PM | #1 |
What kind of fuel mileage is every one getting
I have 420 hp, 32 inch rear tire, 3.08 gears, 700r4 with 30% lower first gear and a taller over drive gear, i think it is .67. I think i am going to get 23- 25 miles per gallon.
04-09-2010, 11:17 PM | #2 |
Grandpa in the rustmobile...
Re: What kind of fuel mileage is every one getting
wuhhhh
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-09-2010, 11:28 PM | #3 |
20' Daredevil (Ret)
molinehotrod, it'll be interesting to hear what you actually get....
With three tanks, mine's kind of a pita to check, and I've only bothered once, many years ago, on a 3,500+ mile norcal - kansas - norcal trip in the dead of winter. I got 11.5 mpg. I only made one other attempt to check it, a couple years ago, fall through spring. On colder mornings, it was on fast idle for several minutes to warm up so the windshield would clear. Then just a couple minutes to work, and much the same for the trip home after work. I added up what I had put in, several tanks worth. Did the math. Came out to two mpg -- yup, you read that right.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 04-10-2010 at 05:18 PM. |
04-09-2010, 11:34 PM | #4 |
10 mpg, but I do it with and ear to ear grin.....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-09-2010, 11:34 PM | #5 |
23-25mpg? If you drive it like a grandma. Maybe 14.
04-09-2010, 11:38 PM | #6 |
No way you getting 23-25mpg with 420hp unless someone is pulling you. Sorry to say you figured something wrong
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project Last edited by srea76; 04-09-2010 at 11:39 PM. |
04-09-2010, 11:46 PM | #7 |
not hapining!
I would recomend that since you are nowhere near stock gearing / tire size / transmision, you will have to put an adapter on your cable to correct your spedo. A local spedo shop would be able to take care of that for you. Only then could you even figure your mileage. I guess another way would be with a full tank of gas and a gps. Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! |
04-09-2010, 11:47 PM | #8 |
You guys need to read the specs, 75 mph i turn 1625 rpm and she is just purring down the road.
04-09-2010, 11:59 PM | #9 |
20' Daredevil (Ret)
You're still pushing a brick through the air... good luck, but it sounds a bit ambitious.
Our V6 Tacoma is geared fairly tall, and it typically gets 18 mpg on the highway.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 04-10-2010 at 12:01 AM. |
04-10-2010, 12:04 AM | #10 |
I would be seriously shocked if you got 15 with a 420hp engine with a carb
04-10-2010, 12:57 AM | #11 |
ls1 f-bodies ran even less on the highway and were only rated at 28 mpg with fuel injection, a more conservative engine setup of course, and a .5:1 6th coupled with 3.42's. There's not a snowball's chance in hell you're getting anywhere near that.
'72 cheyenne super step, '05 long bed gmc |
04-10-2010, 01:03 AM | #12 |
The snow is falling in snow ball form.
04-10-2010, 01:10 AM | #13 |
Hey guys i am going to call it a night and go measure the miles around here and make sure thay are not cutting these mile short in this part of the country. And those fuel tickets must all be wrong. Especially that 450 mile trip from salina ks to loveland co. thanks guys, I going to go get my money back from all of those gas stations that over charged me. thanks for your help!
04-10-2010, 01:10 AM | #14 |
haha, I don't think anyone here is trying to mob you with snow balls, but reality check is in store. If you're getting that good of gas mileage out of those, you really need to write some books on your tricks, especially in this "eco-age", you'll rake in some money!
By the way, nice Radirs, love those wheels! Heck, that entire rig there is style for miles, nice work!
get it! |
04-10-2010, 12:20 AM | #15 |
yeah, those tires are tall and rear gear high, so highway cruising might not be bad in OD, but I still think you're being VERY optimistic!!
city driving will probably suck up the fumes quick too! That's a tall tire to get rolling with your gearing alterations... And keep in mind that rpm at a given speed doesn't tell the whole story. Depend on how heavy your foot is and how far down you have to push to keep that "brick" moving at that rate of speed, not to mention how quick you want to get there!
get it! Last edited by ShredSled; 04-10-2010 at 12:24 AM. |
04-10-2010, 12:30 AM | #16 |
Guys before my suspension change with same motor and 28 inch tires all the way around i ranged from 22-23 mpg I don't know how but it is great. Look at a 98 and up camaro with six speed 23-25 on highway with a smaller tire and shorter gear. Think about it.
04-10-2010, 12:41 AM | #17 |
as stated, there is no way with your combos your spedo is even close to accurate.
04-10-2010, 12:45 AM | #18 |
camaro is also much more aerodynamic.
You'll be getting better gas mileage than just about any brand new truck on the road, with their VVT and DoD and all the other fuel saving technology...
get it! |
04-10-2010, 12:53 AM | #19 |
So will you please explain to me how i am getting 21 mpg with this. 31 chrysler with 330 desoto hemi with 6-71 blower 20 % underdriven with three twos, 200r trans, 342 rear gear and a 29inch rear tire.
04-10-2010, 01:00 AM | #20 |
you're not. choose the correct speedometer gears for your trans. Can't rely on a fuel gauge to be correct either as far as how much gas you have to put in
04-10-2010, 01:02 AM | #21 |
I doubt that thing has ever been on the freeway long enough to get a mpg reading. it spends most its time idling and cruising.
Im not hating, trust me I wish our trucks could get killer mileage, its just not gonna happen.
04-10-2010, 01:08 AM | #22 |
So not ONE other person in this thread is going to talk about THEIR mpgs as th title states... Well I get around 12 mpg if im lucky, though its a bit rough as a DD right now with long trips. Everyone else is just having fun ganging up on the guy, if hes right hes right, if hes wrong hes wrong, doesnt effect you anyway shape or form, relax.
04-10-2010, 01:12 AM | #23 |
Big Red - Now its a SWB!
Carb or efi?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
04-10-2010, 01:27 AM | #24 |
I get 10 mpg with 35's and 3:73's with my 350/ 350 combo in my 72 k10. my 07' work truck with a 6.0 gets 13 mpg with 32" and its fuel injected.
04-10-2010, 06:23 AM | #25 |
Green club
I'm getting 12.5 average with mine. Mild 355/700r4 and a 3.42 rear gear with a 28" tall tire.
On the freeway about 70 it's turning about 2K, add wind etc and the engine will labor a bit to hold speed so mileage goes in the crapper Around town I am getting 10 I imagine. I have had it as high as 15 once freeway driving, warm calm day and no traffic but those days are few and far between.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
