04-10-2010, 05:28 PM | #1 |
Post pics of lowest spring set-up
Drop springs front and rear, and lots of modifications
04-10-2010, 06:40 PM | #2 |
Re: Post pics of lowest spring set-up
That looks really good man. I like it a lot
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
04-10-2010, 09:38 PM | #3 |
vw guy & now c-10 guy
that does look really good.
post up some specs brother, I'd like to know what you've done. I have a 5.5/7 static drop but it sure doesn't look like that! lol |
04-11-2010, 12:26 AM | #4 |
Exactly what im tryin to do with my 81 and a static drop. May we see more pics and some more info on the front end mods please? Thanks!
04-11-2010, 10:36 AM | #5 |
guys i've got drop spindals,drop springs that i cut a coil off, then i moved the cross member up in the rails 2 inches, notched front rail for steering to clear, moved shock mounts,new motor mounts, new trans cross member, new trailing arm cross member, new rear shock mount cross member, z'd rear frame 4 1/2 inches and you cant tell, when i z'd the frame i did it vey tasfully, you can look at it not tell that it is z'd, i have 4 inch drop blocks and drop springs. The front i had to narrow the front a arms 1 1/2 inches so that i could turn. I work at a rod shop and we had a customer that wanted air ride, so we got him the rear air bar kit and front a-arms and bags with drop spindals, and all the digital controls, i think the kit was like 6500 from air ride, well he was upset that he was aired out and i was two inches lower than him. I've got about 200 in steel to get the frame down. i already had all the springs and spindals.
04-11-2010, 12:51 PM | #6 | |
Porterbuilt products would have been a better choice for extreme air-ride drop as would other companies....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-11-2010 at 12:52 PM. |
04-11-2010, 11:39 AM | #8 |
I'd like to see pictures of your rear Z, if you have some.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
04-11-2010, 12:05 PM | #9 |
low n' slo
^^ x2
that looks great for being static dropped. its funny your lower than a lot of bagged rides lol. so do you ever plan on bagging it...and how hard is it to drive?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-16-2010, 12:41 AM | #10 |
*NO REGRETS*
Dig it! Any updated pics?
02-10-2012, 07:59 PM | #11 |
Update?
Are you even still on here anymore? probably not. |
