04-15-2010, 06:22 PM | #1 |
The oddest Todd around
Burning Rubber Smell (not joking)
I have a 72 c10 lwb, and when I am doing about 60-70 I can start to smell what smells like burning rubber smell. Gets worse if I go faster.
I can smell it better if I ONLY have the wing window open partially. I've checked my spark plug wires, and other wires under the hood, but they are all fine. I have replaced the front calipers, pads, and rotors, but no change. When changing the rotors, I replaced the bearings and grease, and packed the crap out of it, but no change. Also, around 85ish, I get a hell of a vibration. I've checked the tire balance, and of course like I said I replaced the bearings, so I don't know where the vibration is coming from either. What could be causing the burning rubber smell? At 70ish? Could the u-joint bearings for my driveshaft maybe smell like that if they need more grease? I am also suspicious of the transmission may be going out, though I am not having a problem with slipping or popping out of gear. I'm supposed to have a 2400 stall torque converter, but it is still the stock stall. I'm at my wits end here.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
04-15-2010, 06:28 PM | #2 |
Between Trucks...
Re: Burning Rubber Smell (not joking)
Belts?
Beat it to fit, Paint it to match... |
04-15-2010, 06:29 PM | #3 |
Yeah... I checked those, and it's not them or the hoses.
04-15-2010, 06:33 PM | #4 |
Tires?
Cheers, Charlie
1968 C10 Truck LWB Fleetside 1968 C10 Truck SWB Stepside 1994 K2500 Ext Cab Fleetside 2008 Honda Civic Si *lease* |
04-15-2010, 08:09 PM | #5 |
Hardy Har Har...
I WISH I could roast the tires at 70...ish...
04-15-2010, 08:27 PM | #6 |
Grandpa in the rustmobile...
You cant roast tires at 70mph?!!!! I think you need to check your blinker fluid??
Honestly, good luck! plug wires melting or something???
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-15-2010, 08:35 PM | #7 |
Do you have a 2 piece driveshaft? If so i'll bet you a 12 pack that the carrier bearing is on its way out. Verify by driving it at speed then touching it. It will be hot,
04-15-2010, 08:43 PM | #8 |
I dun gradjiated collij!!!
^^^Beat me to it...the bearing gets red hot and the rubber around it starts to burn...I'd check it out quickly though, as enough heat and it will seize, or possibly ignite...either way its bad news....
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 04-15-2010 at 09:40 PM. |
04-15-2010, 09:59 PM | #9 |
2 years ago I replaced the 2 piece drive shaft and carrier bearing with a 1 piece drive shaft.
04-15-2010, 08:37 PM | #10 |
mine was ignition switch but smelled like electrcal and rubber
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
04-15-2010, 08:51 PM | #11 |
my ignition switch went out and IT STUNK!! UHH NEVER SMELLED SUCH AN AWFUL SMELL.....but if its working then..lol
Carrier bearing sounds possible
04-15-2010, 11:50 PM | #12 |
Check your starter wires and cable possibly to close to exhaust.
04-16-2010, 12:07 AM | #13 |
What?
Sometimes U joint grease or oil getting slung around and on the exhaust can smell like burning rubber.
Any mud or gunk on the drive shaft? Lose a weight on the drive shaft? Dented drive shaft? How old are the tires? Could have a tread starting to separate.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
04-16-2010, 12:16 AM | #14 |
After I changed tires, they had a slight rub on the inside of the wheel well. But I could smell it driving around town. So it was quick to be fixed.
04-16-2010, 05:46 PM | #15 |
had the same smell, block huggers were contacting the rubber on the driverside motor mount.
04-16-2010, 06:00 PM | #16 |
I was gonna say carrier bearing too, Also maybe the rear end is real low on fluid? and the residual is burning
1967custom |
04-19-2010, 01:00 AM | #17 |
spark plug boot touching the header?
04-19-2010, 03:01 AM | #18 |
Troubleshooting. My favorite, next to root canal. If just your wing window is open, it may be causing low pressure in the cab, causing the air to be sucked in from other places, usually the AC/heater system, which gets the air from the cowl vent in front of the windscreen. That air comes from the front of the truck. At 70 mph, the air is moving pretty fast and probably can't be coming from anywhere aft of the cab.
So that leaves the engine compartment. What is rubber in there? Plenty. What smells (remotely) like rubber? Coolant may have a rubber smell if it is dirty or really thin (Heater core or hose forward of the firewall). ATF leak hitting hot parts? If automatic, it could be a leak in the trans cooling lines, and at speed the wind might blow it up to the headers, same with the power steering. The only place rubber parts might hit hot parts would be the plug wires, or random hoses that are out of place. But you would smell it at slower speeds, too. Maybe look for burned stuff on the exhaust parts. Did you check for cupping or uneven wear on the front tires? It sounds like you have checked all the obvous causes, but what about the odd ones? A front tire out of alignment or camber (maybe), or both so you don't feel a pull, might cause them to slightly slide, increasing some lateral friction. A slightly bent or warped (or loose) rim might not be noticable at low speeds but might cause the same lateral friction and maybe even a vibration at higher speeds (?). The fact of the matter is that the only things that really change at higher speeds is the speed at which the tires rotate. The engine is pretty much in the same operating parameters as at lower speeds, only the tires and wind speeds change (in the front half of the truck). I don't know, but I'm leaning towards the odd, very odd, possibility that it is your front tires. Feel them after a drive and compare the heat to your rear tires. They should be the same. I have the strangest luck when it comes to seemingly obvious symptoms. I once smelled burning rubber at speed and it turned out to be a rabbit stuck in my lower radiator mount area. You would think it would smell like chicken.
www.coolmoodart.com Last edited by Diablo de la Noche; 04-19-2010 at 03:17 AM. |
04-19-2010, 06:44 AM | #19 |
I would look for the causes of the vibrations. . . You may have two unrelated issues. 70 and faster vibrations (You mean these things can go that fast?) Are there any unusual sounds that go with the vib? Have you put her in neutral during the vibs to isolate drive train? What was the last thing you messed with before it acted up?
72 Chevy C-10 Custom LWB 383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb. Hooker Comp Headers w/ X-Pipe and 2.25 duals TKO-500 & 3.08:1 rear I Love HEMI's, they're soft & chewy! |
04-20-2010, 08:48 AM | #20 |
Check the harmonic balancer, it could possibly be coming apart. Also a cause for vibration.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! Last edited by RustyParts; 04-20-2010 at 08:50 AM. |
04-26-2010, 04:10 PM | #21 |
Harmonic Balancer... wouldn't this smell at a specific engine speed?
I've put it in 2, and revved it up to 3500rpm, and no smell. Leads me to believe it isn't connected to the engine. Could a bad brake hose cause the caliper to drag? Or... could a dragging brake smell like burning rubber? The only burning stuff under the motor is an oil leak off of the back of the motor by the oil filter. But it doesn't smell when the engine is running in park with the hood popped...
