Old 04-17-2010, 08:42 PM   #1
The Raven
Serpentine conversion
How hard is it to convert from v-belt to serpentine and what special tools will I need
The Raven is offline   Reply With Quote
Old 04-17-2010, 08:45 PM   #2
87gmcsierra
87gmcsierra's Avatar
Re: Serpentine conversion
why would you wanna do that? , i would just stick with the old style unless somethin is screw up with it.
87gmcsierra is offline   Reply With Quote
Old 04-17-2010, 10:35 PM   #3
joe231
joe231's Avatar
You don't need any special tools. You just need the serp set up and a reverse rotation water pump. There are a couple threaded holes that aren't in the older heads, they aren't necessary though. You will probably want to grab all the hardware while you are at it.
I'm in the process of converting to a serp set up on my crew.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 04-18-2010, 01:57 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Easy bolt on installation!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 04-18-2010, 02:26 AM   #5
USSkoval
What are those brackets from? I don't recognize those specific ones.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 04-18-2010, 07:44 PM   #6
gchemist
gchemist's Avatar
Mine are off a Blazer. The brackets are spaced closer at the top. Any 93-95 truck brackets bolt on. Truck brackets don't have a provision for a smog pump.
Old 04-18-2010, 03:23 AM   #7
spinem
haha, ford guys...
your belts a little loose
spinem is offline   Reply With Quote
Old 04-18-2010, 10:50 AM   #8
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I just got back from the pick-n-pull and grabbed the other side I needed. When I eventually become a paying member, I will put an ad out for it.
You can get them from 88-92 v8 camaro's and trans-am... worked great on my BBC with a little modification, otherwise a bolt on for SBC
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-18-2010, 11:20 AM   #9
SatisTraction
WTB 73-87 SWB fleetside bed!!
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
75 bronco injected 351w
SatisTraction is offline   Reply With Quote
Old 04-18-2010, 04:28 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
SatisTraction- Please don't turn this in to a WTB, For sale thread. If you have an item that might be of interest, post it in the Classified Forum and offer a link...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-18-2010, 09:23 PM   #11
SatisTraction
gotcha.
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
Old 04-18-2010, 08:34 PM   #12
toms84ss
The only "special" tools you'll need are some Torx bits for some of the fasteners. I believe its a T-45 for the bracket bolts on the heads and block.
toms84ss is offline   Reply With Quote
Old 04-18-2010, 08:44 PM   #13
joe231
joe231's Avatar
Neither my '89 burb serp set up, nor a '95 c1500 I helped tear down had any torx bolts....what year and model did you encounter torx bolts?
CHEVY ONLY
Old 04-18-2010, 09:13 PM   #14
toms84ss
I have run across these in a '92 Buick Roadmaster, '89 Chevy Caprice, and several 88 up Camaro's and Firebird's. Maybe the truck set ups did away with the Torx headed bolts?
Old 04-18-2010, 09:31 PM   #15
85gmcguy
Plays with trucks
85gmcguy's Avatar
http://www.carcraft.com/techarticles...ive/index.html
This pretty much covers it.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 04-18-2010, 10:29 PM   #16
73chevyman
73chevyman's Avatar
theres a suburban around me that I'm gonna get the serp set off of... then I'm going to electric fan..... serp set up to me is much cleaner look the the old v-belts
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 04-19-2010, 03:36 PM   #17
87Bob
I got my set up off a 92 S-10 4.2. A guy was parting one out and I paid
50.00. I got it all not just the brackets but the pumps(steering and water), compressor and alternator. I have had the brackets powder coated he alternator rebuilt and just have the steering pump and AC compressor to go through.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 05-10-2010, 02:21 PM   #18
cheyenne402
The water pump is different? I am parting out a 1989 suburban and I took the serpentine set-up off it. I am going to put it on my 1986 C-10.
Just wondering if waterpump is different between the two? Thanks.
cheyenne402 is offline   Reply With Quote
Old 05-10-2010, 02:28 PM   #19
toms84ss
The water pump is reverse rotation because of the belt routing.
Old 05-10-2010, 02:40 PM   #20
cheyenne402
I don't need the balancer do I? or can I use the stock one I have on the 1986?
Old 05-10-2010, 02:45 PM   #21
toms84ss
You can use the stock balancer with the serpentine pulley.
Old 05-10-2010, 07:37 PM   #22
gchemist
gchemist's Avatar
Yes, all you need is a V-8 crank serpentine pulley.
Old 05-10-2010, 02:53 PM   #23
cheyenne402
sweet thanks
Old 05-10-2010, 03:58 PM   #24
spr85gmc
spr85gmc's Avatar
Will a serpentine belt off of a 98 suburban work on my 87 350
spr85gmc is offline   Reply With Quote
Old 05-10-2010, 07:37 PM   #25
Kalashnikov46
Kalashnikov46's Avatar
stick with the v belts. serpentine really dont look that much better cause they're still ugly but at least with the v belt if your on a trip and your compressor goes out or your p/s pump goes out you can stick a smaller belt on and bypass those systems entirely, infact i keep extra smaller belts along with the regulars just for that.
-Bear
Here comes the devil doing 99...
facebook page thingy
Kalashnikov46 is offline   Reply With Quote
